thing with the chain on this one, it can be sloppy and won't affect how it runs all that much since the timing is triggered off the crank. The slack won't affect it. Easy enough to see if you need to worry though. Pull the distributor cap off and put a breaker bar on the crank pulley. 15/16" IIRC. Rock the crank back and forth and note how far it goes before the rotor moves. A tight chain will have very little crank movement before the rotor moves.
My 1983 Continental Mark VI!
I have an appointment to get the exhaust leak fixed Friday. I’ve put about 600 miles on the car so far in the two weeks I’ve had it. No leaks, trans fluid looks really good, no oil consumption granted it’s a little early to tell. The receipt I have from June shows that there’s just over 1,000 miles on the oil and filter. Plugs, wires, cap, and rotor were also changed back in June. Why the previous owner spent the money on a K&N oil filter but didn’t replace the filthy and undersized air filter I’ll never know.
Everything seems to be going good other than that issue I had from the fuel pump inertia switch. My NOS one showed up this morning and I got it installed. The old one was so bad you could tap it with your hand and trip it.
I noticed “Made in England” on both the original and replacement switch. I’m thinking Lucas? No wonder it was an issue, I also recall that gadget73 was having issues with his at the last ScottFest I made it to, 2015 if I recall correctly?
I really need to stop treating this thing like it’s my daily, but it’s just so nice to drive.
Turns out my problem was actually the connector. I got another inertia switch from the yard because I thought that was it, but the plug fell apart when I went to change it. The terminals were cooked. Changed the plug and the switch and it's been fine since.
I like cars that *could* be used as a daily if needed. means they are reliable enough to actually use instead of look at.86 Lincoln Town Car (Galactica).
I got an answer to my last question from gadget73 over on LincolnsOnline.
But I have another question, this one about A/C. I haven't messed with an A/C system in about 10 years and even then I only so so knew what I was doing. I noticed while sitting in line at a drive through tonight for between 5 and 10 minutes that the A/C compressor never cycled on/off it just ran constantly. Is this normal or is it a sign that the system could be over filled? My '88 MGM used to cycle a fair bit but at the same time I don't know if that was right. I could never tell what was going on with the newer panthers like my '02 LSE because you can't really tell that the compressor is running unless your watching it.Last edited by mercurygm88; 07-18-2021, 10:10 PM.
On hot days, the A/C compressor will seldom cycle, if at all. When it’s a bit milder you’ll catch more normal cycling activity.
My Cars:
Originally posted by Kodachrome Wolf View PostOn hot days, the A/C compressor will seldom cycle, if at all. When it’s a bit milder you’ll catch more normal cycling activity.
Yah, what K wolf said. You know it's probably good if it's hot as balls yet the compressor never cycles, at least at idle. If is cycling, probably low and or other issues lurking. Not an A/C guy, but like the Lynyrd Skynyrd song, I know a little.1985 LTD Crown Victoria - SOLD
Originally posted by DerekTheGreat View PostYah, what K wolf said. You know it's probably good if it's hot as balls yet the compressor never cycles, at least at idle. If is cycling, probably low and or other issues lurking. Not an A/C guy, but like the Lynyrd Skynyrd song, I know a little.
there is a temperature vs cycles per minute chart in the service manuals but generally over 80 or so it runs pretty steady, especially at idle.86 Lincoln Town Car (Galactica).
So I'm trying to narrow down this random no start issue. The car always ends up starting eventually and once it's running it's good, and will re start just fine if I shut it off. The issue seems to arise after it sits for 8 plus hours. I've determined that any time it happens I do in fact have spark, I also know that the fuel pump is running. My guess is that when the car sits all of the fuel in the lines runs back to the tank, and when I go to start it I have to refill the entire fuel line from tank to engine. So I guess my big question is what is supposed to keep fuel from returning to the tank when the car isn't running? I'm thinking that is what I need to look into.
If I'm not mistaken, and I very well could be, the check valve is part of the pump itself.
If you can reproduce the issue every time in the morning or after the car has been sitting try turning the key multiple times to the run position but not as far as the start position. After doing that several time the pump should prime the lines and if it starts right up then your suspicion of fuel would be confirmed. This assumes you have an electric in-tank pump like the sefi boxes up to '89 that I'm used to dealing with, which I'm pretty sure it does.Vic
Originally posted by VicCrownVic View PostIf I'm not mistaken, and I very well could be, the check valve is part of the pump itself.
According to the records I have the pump was replaced about 15,000 miles ago, but that was also back in 2002. I have service records going back to 1985 with no apparent gaps showing that this car has 33,000 mile on it. The title says 132,000 because either someone didn't know or the title department pulled their typical crap with 5 digit odometers. Ohio usually doesn't do a forced mileage discrepancy but it can happen. All of our title departments/registration offices are privately owned and run now and none of them seem to know what's going on.
I have no intention of replacing the fuel pump unless I absolutely have too, I wonder if there is a simple way to get the pump to continuously run when the key is in the run position? Or if that would negatively affect anything?Last edited by mercurygm88; 07-20-2021, 04:10 PM.
