it is hard too do burnouts with no brakes, unless i chock the front wheels
Nitrous swallowing, fire breathing Windsor Now with videos
Originally posted by phayzer5its only 10-20 minutes hovering a few hundred rpms around 2k, then there's the first few oil changes to get out of the way....then the burnout christening!!
You need to change RPM occasionally while running between 1500 and 2000.
Got my new rockers today they are 1.72 Scorpion full rollers they are used but only for a few hours
nice rockers! get er done mang
Got the 1.72 Roller Rockers installed today. Also changed out the break in oil , and installed the dual remote oil filters.
so all i have left is to tune the carb, a new radiator since i sprung a leak in the old one, Brakes for the rear, a banjo bolt and 2 washers for one front caliper, and i should rebuild the front suspension since i tore some ball joint boots changing springs. Besides that i need to finish removing the sound deadening , reinstall the seat and seat belts. Also need to get the alternator straightned out it is charging only 13 volts and is squelling and getting the belt very hot. i will have some new pics up in a few minuteshttp://secondhandracing.com/Home.aspx
Is that a pair of FL-1 or what?86 Lincoln Town Car (Galactica).
Originally posted by gadget73Is that a pair of FL-1 or what?http://secondhandracing.com/Home.aspx
