Just a thought I had as I was going through my brochure collection. When I got my Ford pack a couple years ago the seller included a couple for the baby LTD and I really like the black with white text levers on the steering column. The black shifter is sexy too. :heyhey:
Would the levers from a baby LTD mate to our columns?
If it's just the black levers you're after, base Panthers did come with black left-side levers for at least a few years. Don't know whether the black wiper lever could be had with delay wipers, though. I would imagine a Mustang/Fairmont forum would help you find info on the physical dimensions of typical Fox-body wiper and multifunction switches, particularly the screw-hole spacing. I do happen to know that different year Mustangs used different plugs on the multifunction switch, so depending on the source of the switches, different pigtails may or may not need to be spliced in (or swap to individual spade connectors!).2012 Mazda5 Touring | Finally working on the LTD again!
I believe some Tbirds had those levers. I've had the turn signal one in my hands before. NOS, and other than the fact it was black it was identical to a Panther part. 84- type though with the stalk horn. I *think* it may be Tom's, but I don't know for sure. It wasn't all that long ago I was looking at it though.86 Lincoln Town Car (Galactica).
david and i harvested the wiper switch, tilt lever and multifnction switch lever today from an 81 thunderbird......i do believe they will werk mang
the tilt lever screwed right in. looks cool.~David~
they look exactly like the peeling chrome ones on my car, just black. Once i get home i will up load some pictures of the levers.~David~
here is a photo of two levers.
i installed the directional one and it is a little loose..mabe because it was meant for the horn.???~David~
yup, i got an NOS chrome one with horn and it slides in and out a little, lolPete ::::>>> resident LED addict and CFI defector LED bulb replacements
i might put a dab of silicone around it to prevent it from flying around on me...if and only if the wiper lever is correct.~David~
If you compare the grooves cut on the horn style lever vs the non-horn one you'll see why its loose. I wonder if using some jb weld or something of that nature to fill in the groove and make it match the non-horn one wouldn't do the job.86 Lincoln Town Car (Galactica).
can you use the old school switch by any chance?
i have no idea about the old school switch i didnt check it out yet.~David~
