How are they clocked though. Really makes no difference but I found it nice that the mustang one had everything in easy to reach locations.
front cig liters dead... like so many other things
that part I don't know... but three bolts out and rotate to your preferred clock so it's not really an issue.
What kind of amp do you have? It sounds like its maxed out or getting a bad voltage drop... what size power wire are you using? And why the hell is the sub in the back seat? lolPete ::::>>> resident LED addict and CFI defector LED bulb replacements
Pioneer 600 watt rms 1200 max!!!! 4 gauge power wire. the sub is in the car because it is so cold i need to help it warm up plus sounds better!!!
im getting a new car soon but i was asking about the fuses i need to know where the fuse is located for 1. the horn 2. front cigarette lighter thanks
Originally posted by vitals_fading View PostPioneer 600 watt rms 1200 max!!!! 4 gauge power wire. the sub is in the car because it is so cold i need to help it warm up plus sounds better!!!
20amp
Dave said it earlier....
Might be a different position for the TownCar but it's a good place to start and it should still be a 20amp.Last edited by 86VickyLX; 01-10-2011, 02:05 AM.
Can you see the top of the broken lock pull up thingy on the back door when you look down into the hole?
You might get lucky and be able to move it to the hole with a nail or something, and have a friend hit the power lock, maybe get the back door to open.
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
Originally posted by 87gtVIC View PostReferring to your video....
I think you need to invest in a 130amp alternator...that along with the big three would help tremendously. Cant really do the big 3 with a 2g alternator...assuming that is what your car has.
you need more power.
(in tim allens voice)1988 MGM GS - Preferred Equipment Package 172A; InstaClear
1994 MGM GS Montigua
2002 Mustang GT Coupe
