uhh...where is it?
dumb question about the fuse box
'88 Colony Park, white with wood grain contact paper, K code axle, hose pliers on heater hoses, factory duals, big plans in the future...
'83 Toyota 4x4, 31x10.50 15, could use a new carb, custom humidifying holes in the roof, mud based paint...Tags: None
Under the dash on the driver's side. Exactly what year and model are you working on? Later models might also have an under-hood panel.86 Lincoln Town Car (Galactica).
79-89 vics and gmq's require removing the dash panel under the steering column to get the the fuse panelPete ::::>>> resident LED addict and CFI defector LED bulb replacements
i found it, thanx. well my girlfriend did (i'm so ashamed). it;s an 88 GM, good place to hide it thuogh, too bad they didn't think to label it'88 Colony Park, white with wood grain contact paper, K code axle, hose pliers on heater hoses, factory duals, big plans in the future...
