Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: {DRIVETRAIN}Rear end build up! NEED TO KNOW?
  1. #21
    39,086
    Also not sure if the rear discs from a 'stang rear woudl work properly with the E brake cables from a box. You coudl strip the gears out if nothing else, assuming its an 8.8" rear.
  2. #22
    Mar 2005
    Virginia Beach
    8,218
    How are you measuring offset? Is neagative father in from center or out?
    I don't want to go farther in from center. I'd like it to be center.
  3. #23
    Lets put cough drops in out buttholes and play video games DuceAnAHalf's Avatar
    florida
    6,674
    when the mounting flange of the wheel is inboard of the centerline of the wheel it has negative offset
  4. #24
