$125 obo shipped!!!!!!!! MAF is not in the pic but IS included. K&N filter NOT included.
P71 (Marauder style) air box / MAF / zip tube
85HPP's most noteworthy mods: CFI to SEFI conversion w/HO upperstuff headers & flowmasters P71 airbox Towncar seats LED dash light-show center console w/5 gauge package LED 3rd brake light 3G alternator mini starter washer/coolant bottle upgrade Towncar power trunk pull underhood fuse/relay box 16" HPP wheels - police swaybars w/poly rubbers - budget Alpine driven 10 speaker stereoTags: None
For those that don't know, this is the woo-woo factory airbox that all the modular guys want.
Im not sure, but I believe you'll have to re-wire the MAF sensor to put it in anything besides a 03+ P71 (someone correct me if Im wrong) and may require a "tune' to run right.
You can put one of these in a box with some modification/relocation of things in your driver fender area. Installing a 90-91 vic/gmq inner fender makes it a clean bolt-in install (as far as fitting the air-box)Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
I've definitely got some interest in this...I have a box and inlet tube already from a mid-90's CV...but the inlet tube doesn't fit my 75mm t/b...can the price be trimmed if the MAF sensor isn't included?
Let me know what you want for it shipped to 29803...I'm re-couping from buying a FAST EZ-Efi set up but my state tax returns should be coming back very shortly.
Thanks,
Don'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
I'm trying to sell it with the MAF to keep the price up, the MAF alone isn't worth much.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Yeah that's kinda what I figured...will it fit an aftermarket 75mm t/b? My trick flow t/b has just a little bigger O.D. than a factory t/b. I'd love it if it'll fit...I would imagine it SHOULD...do you have an I.D. measurement on the t/b end of the inlet tube?
If it's close to my t/b O.D. size then I'll just need to know where to send the check.
Thanks,
If your TB is bigger it might not work, its a nice snug fit on my stock size and I don't think the OD size of panther TBs really changed much.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
check the OD of the TB. That's the important bit. Stock TB has a pretty thick wall. The aftermarket ones are typically pretty thin.
My trick flow t/b measures 3 1/4" O.D....I have a stock panther t/b that measures just a cooter hair over 3 1/8" O.D. Maybe a warmed up hose and some silicone spray will help it slip on...worst case scenerio, it doesn't work and I just put it back up for sale...lol.
PM me your address so I can send you a check.
Thanks,
PM sent!Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
PM replied'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
