Just got done reading Mr Bean's modbox thread again, a lot of stuff came back from memory but I learned a couple new things. Took plenty of detailed notes too. I am reasonably confident Eva can get the '03+ frame swap done over the summer. I have a good running SEFI 302 out of an '88 Grand Marquis. AOD works great too. How much does this complicate the swap? Because I'm not just putting old body on new chassis; I'm doing that plus putting old driveline. How much does this add to the bottom line in terms of time and money?
I know for a fact the engine cradles and motor mounts were different on SBF versus modular cars. Thankfully from what I've read on other sites, you can easily swap cradles via cutting and welding; they should fit without any difficulty. Just the standard measure twice, cut once stuff. But what about the transmission crossmember, and driveshaft? What does running an SBF and AOD in an '03+ chassis mean for wiring and all that stuff? How do I get my '85-'89 steering wheel and shift linkage to work nicely with the '03+ rack and pinion system? I'm not averse to shelling out for some custom parts here and there but I also would like to not spend more than say, $4500 on the entire endeavor. Thanks for any input you can give me.
(And yes I have considered just putting Eva's body on an '03+ frame, replete with its '03+ powertrain. I just don't want to open another can of worms, especially since the donor vehicle would be bought for cheap. Don't want to have a car go down for a major engine & transmission service right after being down for a frame swap! But rest assured I am highly interested in mating a 4R75 to an SBF in the future; 4-3-2-1 shift pattern is glorious. But if I have a healthy powertrain available right now, I damn well better use it. Plus there's the whole money issue. I'd need a standalone controller from US Shift, plus I'd need to have the 4R thoroughly gone through to ensure it's ready for the thousands of hard miles I put on my cars in the spring and summer.)
