My 1997 Marquis horn is weak with ignition off and strong with ignition on.why? Thanks
Weird horn
How is your battery doing? Sounds like it may be dickered. Of all the electrical crap in a car, horns usually pull the most current, right behind the starter. So with a weak battery, I could see the horn being weak but when running, a properly functioning alternator will keep the battery at like 14.7V or what not.1985 LTD Crown Victoria - SOLD
+1 battery probably has a weak cell. Have someone crank the car. If it drops below 11V before it starts, you have at least 1 weak or dead cell.
Originally posted by DerekTheGreat View PostHow is your battery doing? Sounds like it may be dickered. Of all the electrical crap in a car, horns usually pull the most current, right behind the starter. So with a weak battery, I could see the horn being weak but when running, a properly functioning alternator will keep the battery at like 14.7V or what not.
03 Mercury Marauder- 63k
Originally posted by DerekTheGreat View PostMo powah!
I've thought about installing the four note Cadillac horns in my cars. That would require quite some juice.Vic
Another thing I want to do2010 Mercury Grand Marquis LS “The Douche” - 70mm throttle body, P71 airbox, 21mm rear sway bay, dual exhaust, Dodge rims, 89K and counting. 4/2018-
1966 Ford Thunderbird (390FE) “Fordy McFordface” - engine rebuild No. 3. 11/2016-
RIP 2005 Buick LaCrosse CXS “Jumba” - gone too soon, 229K. 6/2017-2/2018
RIP 2001 Chevrolet Tracker LT “Featherbrick” - gone too late, 156K POS. 6/2016-9/2016.
Sold 2005 Toyota 4Runner SR5 - 198K. 6/2016-4/2018
