3/25/07 Autocross Pics. Car works pretty well.
The family racecar, my 89 Country Squire
This is a sticky topic.
Haven't done much with the car since '08. Axle has been the cause of many headaches and much money spent. Recently I yanked the tru-trac out and tossed it in the scrap pile and slapped in an old junk trac-lok I had sitting around. Picked up a set of 17x9" and 17x10.5" bullitts with Hoosier A6 slicks on them. Been looking at what I need to do to get the rear ride height where I want.Builder/Owner of Badass Panther Wagons
Originally posted by mrltd View PostHPicked up a set of 17x9" and 17x10.5" bullitts with Hoosier A6 slicks on them.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Is that the IRS swap you talked about a good while back?86 Lincoln Town Car (Galactica).
I was going to say the same thing! I heard about this AGES ago. Way cool is finally getting in there.~David~
Yes and no.... Not the same IRS. The old one was a supercoupe IRS. This one is a performance pack S550 Mustang IRS. Massive brakes, super 8.8, torsen diff, 3.73s, few aftermarket parts tossed on there. Also fits like a friggin dream. Perfect fit between the rails, I'm still using the factory driveshaft (an aluminum one) with a different flange. The downers? I have to make a custom fuel tank, and coilovers have to be used.Builder/Owner of Badass Panther Wagons
How much fabrication did you have to do to get that to mount in there?
Not much at all. Basically some L brackets on the frame for the 4 mounting points. I'll have to make a crossmember for the coilover mounts. Bought a small u joint to large pattern flange for the driveshaft, and used a F150 pinion flange to get the standard 4 bolt flange instead of the CV joint style on the new cars. Fuel tank will need to be made from scratch. I could do the easy thing and throw a fuel cell where the rear seats are, but I want the jump seats-and all that weight out behind the axle isn't good for handling. Plan is to make a tank that goes under the rear seats, similar to BMW, the MN12 chassis, S550 mustang, etc...Builder/Owner of Badass Panther Wagons
Nice
Originally posted by mrltd View Post. Picked up a set of 17x9" and 17x10.5" bullitts
Do you know the manufacturer & backspace of the 17 X 10s?
What year was the rear that was in it at the time?
Thanks Mang
Hey Mike,
Any idea of the bs on the front wheels?
What size tires?
Any clearance issues?
Thanks Mang.
