Just in case anyone was curious what the different EGR spacers look like, here they are. Pics below are (L to R) panther bored to 63mm, Lightning, bored Mustang, and stock Panther.
Pics of the EGR spacers
Everything looks like voodoo if you don't understand how it works -
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Got a couple questions about that Lightning EGR spacer since I'm gonna need one or a suitable substitute for it when I build the EFI 351W. Scott tells me that the reason I need a Lightning spacer is because it has the facility for mounting the throttle and TV cable brackets on it. Does anyone have a picture of how that stuff mounts up so I can see what the goal is?
Also, assuming I won't be running EGR, what do I do? Just leave all the vacuum lines unplugged?
the lightning one looks tiny!!!!!!!Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
no he didnt list em in order of the pics.. ......left to right
bored to 63mm lopo spacer
the uber rare lightning spacer (67mm)
a mustang egr spacer i had bored to 67mm
and the lowly lopo unmodified spacer
nate
see the mounting studs on the right of 3 out of 4 of the spacers? the studs are where the throttle and tv linkage bracket bolt up to the side of the egr spacer........running without an egr spacer, you are going to need to fabricate a bracket to mount the bracket, the geometry for the tv cable is very important remember that
Here are a few shots of the ceramic-coated Lightning one I got from N A on here:
1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
I guess without seeing how it all goes together it'd be hard to totally understand, but it doesn't look like it'd be too difficult to make up something to mount it, especially if I had a spacer to use as a template (I could use a lopo spacer for a pattern, correct?)
Sweet, so the lightning EGR fits without a hitch on the town car, with the throttle and TV linkage and all?1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
it will fit on any 5.0 panther... they are practically the same.
nate, that whole area you circled does not exist on the mustang spacer. youd have to do some serious fabbing to make it work. plus the coolant lines run different too, if you dont omit themPete ::::>>> resident LED addict and CFI defector LED bulb replacements
Hm didn't even notice that the pics attached in that order, and they didn't come out without a filename. Orig post fixed.86 Lincoln Town Car (Galactica).
The coolant lines are sort of useless. Mine are disconnected, and the Explorer lowers don't have a place to connect it anyway.86 Lincoln Town Car (Galactica).
