Here's the rest of the parts I ordered for MAGNA 302X...
a few 1/2way assembled motor pics
Summit Chambered Mufflers Installed
B&M Line Lock kit
Aluminum Water Pump
Oil Pump
Motor Mounts
FRPP E303 Cam
Ford Racing Breather
B&M Tork Master 2000 Stall Torque Converter
1 5/8" Full-Length Headers :banana:
Header Gaskets
HO Governor
B&M Trans Cooler
Mallory Cap 'N' Rotor kit(converts from Socket-style to normal HEI style )
Dorman Harmonic Balancer
Timing Chain
Fuel Pump Eccentric
Oil Pan
Motorcraft Copper Core Spark Plugs
Summit Ignition Coil(since it looks just like an MSD and provides the same voltage for cheaper..why not?
B&M Line Lock kit
Aluminum Water Pump
Oil Pump
Motor Mounts
FRPP E303 Cam
Header Gaskets
HO Governor
B&M Trans Cooler
Timing Chain
Fuel Pump Eccentric
Oil Pan
