replaced the intake manifold nipple with a NPT thread pipe plug
cover the EGR spacer nipples with rubber caps
get rid of the damn heater hose coolant sensor (unless it works) bypass by joining the two wires together.
make a little bracket to let the hose sit pretty, using the AC bottle bracket, after you hack out your AC parts (unless it works)
this is good hose - rubber core, complete fiber seathing, sillicone outer shell.
