VERY 1st post having joined and I joined because of my variable venturi carbuerator. It belongs to my beloved 1982 country squire (wagon of course). OH how can or how DO I be concise??? I wound up leaving the car in storage for 2 full years untouched. I was at last able to go get it back in time for Christmas 2012. Got it back home here and proceeded to drive it as my everyday driver again. true to its previous life it was an immediate JOY to drive for weeks UNTIL the cold snap hit here in january I guess the choke mechanism (which is 1/2 inside the carb) "sticks". I'm sick about getting rid of the car, I CANNOT afford the near 300.00 price tag to have it worked on I'M PETRIFIED to work on that choke myself, I have never touched a "carb" before ever and I hear and read that the VV "quite a carb"! IS the VV carb as difficult as I hear?
variable venturi carbuerators anyone.....I hope????!!!!!
Patience, this site doesn't get massive traffic this time of day and almost nobody here knows anything about the VV, other than to tell you it sucks. Well, it does suck, but thats not the question. If its working normally other than just a sticky choke, I'd try washing the choke linkage off with some carb cleaner to de-gum it. That may be all you need. If you move the choke plate by hand, you should see all the various bits that move along with it. Just make sure they are all clean and moving freely.86 Lincoln Town Car (Galactica).
Welcome to the site!
I don't have much experience with carbs but I'm sure someone will be along. Things tend to liven up (a little) around evening here.
Only carbs that I have touched were samll engine type stuff like motorcycles, atvs, and lawnmowers.
I once worked on my buddy's dad's car, an old Escort, in my highschool shop class when he was having issues with sticking. We ended up finding that field mice had stored soy beans in the carb/air cleaner which had worked their way down and were causing things to get stuck open.Vic
Originally posted by gadget73 View PostPatience, this site doesn't get massive traffic this time of day and almost nobody here knows anything about the VV, other than to tell you it sucks. Well, it does suck, but thats not the question. If its working normally other than just a sticky choke, I'd try washing the choke linkage off with some carb cleaner to de-gum it. That may be all you need. If you move the choke plate by hand, you should see all the various bits that move along with it. Just make sure they are all clean and moving freely.
Originally posted by t65neon5 View Postwelcome to the club......as far as the VV carb goes,clean the choke linkage as gadget described,also check to see if the "sliders" (the openings at the top.they are square) are not sticking (they do that if they are not clean) and clean those with carb cleaner also
Originally posted by brianradomski View PostUHM quite a while later particularly to gadget: as per your comment about the VV carbtr. Does it suck JUST to work on or in general ? The car really seriosly has been a wonderfully runing car if that carbtrt really .....sucked would it run at all???
Its got really bizzare adjustment procedures. When it works right and someone hasn't stuck the magic screwdriver in there and jacked it up its fine, but if some meathead has been in there already and you do not happen to own the special tools and the knowledge required to set it up, you may as well forget it. The normal fix is to stick a Motorcraft 2100 on there, but thats because a blind monkey could rebuild one of those things and it bolts straight up where the VV was. If it works OK, don't worry about it but you may never find someone who actually has experience with them to properly rebuild it. It would probably turn into one of those things where you learn to do it yourself if you want it done.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostIts got really bizzare adjustment procedures. When it works right and someone hasn't stuck the magic screwdriver in there and jacked it up its fine, but if some meathead has been in there already and you do not happen to own the special tools and the knowledge required to set it up, you may as well forget it. The normal fix is to stick a Motorcraft 2100 on there, but thats because a blind monkey could rebuild one of those things and it bolts straight up where the VV was. If it works OK, don't worry about it but you may never find someone who actually has experience with them to properly rebuild it. It would probably turn into one of those things where you learn to do it yourself if you want it done.
Originally posted by t65neon5 View Post......I actually like the VV carb......but its NOTHING like a regular automotive carb....its more like 1 part holley , 1 part Mikuni , its a "one of a kind" animal , and when it works , it works good , but when it doesn't , well , it can be a pain , partially because its hard to diagnose problems with , partially because not many know how to work on one , and finally , because parts are kinda hard to find for them anymore (the most common response is to replace it with something more "normal" ).....the one I had on my 91 worked well,the only problem I had was the "sliders" were so worn that it would "hang up"...this was solved with a stronger return spring (which gave it a much "firmer" gas pedal...lol)......
