WTB Police or HPP steering gear
    Looking for one of those HPP or P71 steering gear units for my Lincoln, everything else is P71 spec under there and this would be the final piece of the project!
    Car-part.com
    Sent from my XT557 using Tapatalk 2
      If you are going to spent the time and money just order a 02' police spec unit from http://www.redheadsteeringgears.com/ I have one and it was worth the money. Their box eliminated all slop.
        I'm going to try adjusting the slop in my 93... but if I need one after that... I may check that one out.
          I've got one that i pulled from a 00 P71, sitting in my basement right now. PM'd.
          87' Lincoln Town Car Stars + Stripes. Explorer GT40P, Anderson B31 Cam, Shorty Headers, FRPP 1.6 Rockers, A9L, Sn95 T5 Trans, 3:55 Limited Slip, GNX Rear Springs, LSC Turbines, 1.5 wheelspacers, Full Custom Dual 2.5/Flowmasters, 00 P71 Airtube, 19lb calibrated Maf, Summit Alum Radiator, King Cobra Clutch, Short throw Shfter, Energy Susp Trans Mount,
          Mods to come: Big Brake/Poly Front Swap, PI Front Swaybar, Addco 650 Rear Swaybar, Boxed Upper Rear Control Arms, 351/Alum Heads, FRPP Valve Covers,
            ah cool, sounds like a good option, but how much did it set you back?
