1990 steering column
    Im looking for a steering column for a 90. something in my shifter broke feels like a spring but it just alot less work to change the column than to rebuild the shifter.
    Any 90-91 column will at least need bushings unless they've been replaced recently.
    If it still shifts but is a bit sloppy, those bushings may be all you need and they're maybe $10.
    If it doesn't shift at all then you need a shift tube. While replacing the shift tube can be a little tedious, I would rather replace it than replace the whole steering column. Of course it's your call, replacing the whole column might be less time consuming.
    Vic
      There is someone here parting out a (rose color) 90/91 MGM. Car is too nice to part out but does not hurt to check it out.
