So at first i thought it was coming from the air box, then the intake itself, finally i tracked it down this the hose coming off the intake i have no idea where it goes (its circle in red in the pics) by taking the hose off while the car is running you can for sure tell that is where the noise is coming from.
Is this the same problem others have had with a bad IAC?
Edit: the noise is accompanied by a rough idle and staling at stop lights.
