I just found this. And it is gold. Most torque specs. Link below.
http://www.torkspec.com/torkspecme.a...-4.6L-281ci-V8
Torque Specifications for Ford 4.6L-281ci-V8
Type: Bolt Dim: Length: Head: Hexagon Grade:
33 Ft-Lbs
396 In-Lbs
44.74 N-m
Connects: Bell Housing To Engine Block
Years: All Vote Record: Vote
Note: Modular OHC - Except 1998
46 Ft-Lbs
552 In-Lbs
62.37 N-m
Years: 1998-1998 Vote Record: Vote
Note: Modular OHC
19 Ft-Lbs
228 In-Lbs
25.76 N-m
Connects: Bracket/Stay To Timing Chain/Belt Cover
Note: Modular OHC - Coil Pack Bracket to Timing Chain Cover
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Connects: Camshaft To Cylinder Head
Note: Modular OHC - Camshaft Caps
22 Ft-Lbs
264 In-Lbs
29.83 N-m
Connects: Connecting Rod To Crankshaft
Note: Modular OHC Cap Bolts 22 FtLbs + 90deg
Type: Bolt Dim: Length: Head: Grade:
22 Ft-Lbs
264 In-Lbs
29.83 N-m
Connects: Crankshaft To Engine Block
Note: Modular OHC Cap Bolts (Tighten 1st) 22 FtLbs + 90deg
Type: Screw Dim: Length: Head: Grade:
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Note: Modular OHC Jack Screws (Tighten 2nd) Step 4; 7.5
16 Ft-Lbs
192 In-Lbs
21.69 N-m
Note: Modular OHC Side Bolts (Tighten 3rd) Step 7; 16 FtLbs
30 Ft-Lbs
360 In-Lbs
40.67 N-m
Connects: Cylinder Head To Engine Block
Note: Modular DOHC - NOTE: 30FtLbs + 90deg + 90deg
10 Ft-Lbs
120 In-Lbs
13.56 N-m
Connects: Drain Plug To Oil Pan
Note: Modular OHC - Oil Drain Plug EXCEPT 1998
17 Ft-Lbs
204 In-Lbs
23.05 N-m
19 Ft-Lbs
228 In-Lbs
25.76 N-m
Connects: Drive Belt Pulley To Engine Block
Note: Modular OHC - Drive Belt Idler Pulley
19 Ft-Lbs
228 In-Lbs
25.76 N-m
Connects: Drive Belt Tensioner To Engine Block
Note: Modular OHC
Type: Dim: Length: Head: Grade:
16 Ft-Lbs
192 In-Lbs
21.69 N-m
Connects: EGR Valve To Throttle Body
Note: Modular OHC
30 Ft-Lbs
360 In-Lbs
40.67 N-m
Connects: Engine Mount To Engine Block
Note: Modular OHC - Nuts & Bolts
Type: Stud Dim: Length: Head: Nut Grade:
115 Ft-Lbs
1380 In-Lbs
155.92 N-m
Connects: Engine Mount To Cross Member
Note: Modular OHC
15 Ft-Lbs
180 In-Lbs
20.34 N-m
Connects: Exhaust Manifold To Cylinder Head
Note: Modular OHC
Type: Bolt Dim: Length: Head: Nut Grade:
30 Ft-Lbs
360 In-Lbs
40.67 N-m
Connects: Exhaust Pipe To Exhaust Manifold
Note: Modular OHC
3 Ft-Lbs
36 In-Lbs
4.07 N-m
Connects: Fan Blade Housing To Radiator
Note: Modular OHC
62 Ft-Lbs
744 In-Lbs
84.06 N-m
Connects: Flywheel To Crankshaft
Note: Modular OHC
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Connects: Fuel Rail To Intake Manifold
Note: Modular OHC
19 Ft-Lbs
228 In-Lbs
25.76 N-m
Connects: Intake Manifold To Cylinder Head
Note: Modular DOHC - NOTE: 19FtLbs + 90deg
19 Ft-Lbs
228 In-Lbs
25.76 N-m
Note: Modular SOHC - ReTorque When Hot
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Connects: Intake Manifold Plenum To Intake Manifold
Note: Modular DOHC
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Connects: Oil Cooler To Engine Block
Note: Modular OHC
66 Ft-Lbs
792 In-Lbs
89.48 N-m
Connects: Oil Cooler To Oil Filter Adapter
Years: 1996-1996 Vote Record: Vote
Note: Modular OHC - Insert
48 Ft-Lbs
576 In-Lbs
65.08 N-m
Years: 1997-Present Vote Record: Vote
19 Ft-Lbs
228 In-Lbs
25.76 N-m
Connects: Oil Filter Adapter To Engine Block
Note: Modular OHC
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Connects: Oil Pan To Engine Block
Note: Modular OHC
4
15 Ft-Lbs
180 In-Lbs
20.34 N-m
Note: Modular OHC - Step: 15 FtLbs; 60 degs
Type: Dim: Length: Head: Nut Grade:
19 Ft-Lbs
228 In-Lbs
25.76 N-m
Connects: Oil Pickup Tube To Engine Block
Note: Modular OHC - Oil Pickup Tube to Main Bearing Cap Nut
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Connects: Oil Pickup Tube To Oil Pump
Note: Modular OHC
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Connects: Oil Pump To Engine Block
Note: Modular OHC
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Connects: Power Steering Pump To Engine Block
Note: Modular OHC - Power Steering Pump Mounting Bolts
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Connects: Pressure Plate To Flywheel
Note: Modular OHC
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Connects: Pulley To Water Pump
Note: Modular OHC
12 Ft-Lbs
144 In-Lbs
16.27 N-m
Connects: Spark Plug To Cylinder Head
Note: Modular OHC
19 Ft-Lbs
228 In-Lbs
25.76 N-m
Connects: Thermostat Housing To Engine Block
Note: Modular OHC
16 Ft-Lbs
192 In-Lbs
21.69 N-m
Connects: Throttle Body To Intake Manifold Plenum
Note: Modular OHC
19 Ft-Lbs
228 In-Lbs
25.76 N-m
Connects: Timing Chain/Belt Cover To Engine Block
Note: Modular OHC
19 Ft-Lbs
228 In-Lbs
25.76 N-m
Connects: Timing Chain/Belt Guide To Engine Block
Note: Modular OHC - Timing Chain Guide
88 Ft-Lbs
1056 In-Lbs
119.31 N-m
Connects: Timing Chain/Belt Sprocket To Camshaft
Note: Modular OHC
19 Ft-Lbs
228 In-Lbs
25.76 N-m
Connects: Timing Chain/Belt Tensioner To Cylinder Head
Note: Modular OHC - Timing Chaing Tensioner
26 Ft-Lbs
312 In-Lbs
35.25 N-m
Connects: Torque Converter To Flexplate/Driveplate
Note: Modular OHC
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Connects: Valve Cover To Cylinder Head
Note: Modular OHC
118 Ft-Lbs
1416 In-Lbs
159.99 N-m
Connects: Vibration Damper/Hub To Crankshaft
Note: Modular OHC
66 Ft-Lbs
792 In-Lbs
89.48 N-m
Note: Step: 66 FtLbs; Loosen; 36 FtLbs; 90 degrees
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Connects: Water Pump To Engine Block
Note: Modular OHC
33 Ft-Lbs
396 In-Lbs
44.74 N-m
46 Ft-Lbs
552 In-Lbs
62.37 N-m
Note: Modular OHC
19 Ft-Lbs
228 In-Lbs
25.76 N-m
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
22 Ft-Lbs
264 In-Lbs
29.83 N-m
22 Ft-Lbs
264 In-Lbs
29.83 N-m
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
16 Ft-Lbs
192 In-Lbs
21.69 N-m
30 Ft-Lbs
360 In-Lbs
40.67 N-m
10 Ft-Lbs
120 In-Lbs
13.56 N-m
17 Ft-Lbs
204 In-Lbs
23.05 N-m
19 Ft-Lbs
228 In-Lbs
25.76 N-m
19 Ft-Lbs
228 In-Lbs
25.76 N-m
Note: Modular OHC
16 Ft-Lbs
192 In-Lbs
21.69 N-m
Note: Modular OHC
30 Ft-Lbs
360 In-Lbs
40.67 N-m
115 Ft-Lbs
1380 In-Lbs
155.92 N-m
Note: Modular OHC
15 Ft-Lbs
180 In-Lbs
20.34 N-m
Note: Modular OHC
30 Ft-Lbs
360 In-Lbs
40.67 N-m
Note: Modular OHC
3 Ft-Lbs
36 In-Lbs
4.07 N-m
Note: Modular OHC
62 Ft-Lbs
744 In-Lbs
84.06 N-m
Note: Modular OHC
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Note: Modular OHC
19 Ft-Lbs
228 In-Lbs
25.76 N-m
19 Ft-Lbs
228 In-Lbs
25.76 N-m
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Note: Modular DOHC
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Note: Modular OHC
66 Ft-Lbs
792 In-Lbs
89.48 N-m
48 Ft-Lbs
576 In-Lbs
65.08 N-m
19 Ft-Lbs
228 In-Lbs
25.76 N-m
Note: Modular OHC
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Note: Modular OHC
4
15 Ft-Lbs
180 In-Lbs
20.34 N-m
19 Ft-Lbs
228 In-Lbs
25.76 N-m
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Note: Modular OHC
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Note: Modular OHC
18 Ft-Lbs
216 In-Lbs
24.4 N-m
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Note: Modular OHC
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Note: Modular OHC
12 Ft-Lbs
144 In-Lbs
16.27 N-m
Note: Modular OHC
19 Ft-Lbs
228 In-Lbs
25.76 N-m
Note: Modular OHC
16 Ft-Lbs
192 In-Lbs
21.69 N-m
Note: Modular OHC
19 Ft-Lbs
228 In-Lbs
25.76 N-m
Note: Modular OHC
19 Ft-Lbs
228 In-Lbs
25.76 N-m
88 Ft-Lbs
1056 In-Lbs
119.31 N-m
Note: Modular OHC
19 Ft-Lbs
228 In-Lbs
25.76 N-m
26 Ft-Lbs
312 In-Lbs
35.25 N-m
Note: Modular OHC
7.5 Ft-Lbs
90 In-Lbs
10.17 N-m
Note: Modular OHC
118 Ft-Lbs
1416 In-Lbs
159.99 N-m
Note: Modular OHC
66 Ft-Lbs
792 In-Lbs
89.48 N-m
18 Ft-Lbs
216 In-Lbs
24.4 N-m
Note: Modular OHC
