View Post
What brand and weight oil are you using and what mileage interval?
Nasty or hot motors get dark quick. My Beetle ran synthetic blend 20w50 and by 2000 miles it was black. I changed it once a month, which was about a 2500 mile interval. With dino oil it was black by 1000 miles. No dirt in that motor, air cooled engines just bake oil to death. No filter either, so you get short change intervals. I did eventually change it to have a filter, but it was not full-flow, so filter performance was not particularly amazing. better than nothing though. Stock design was this basket thing that looked for all the world like a dome of window screen.
In stock form, there is a plate on the bottom of the motor that you undo to drain the oil. Mine had a plate that had a drain plug, so it was a little less messy at least.86 Lincoln Town Car (Galactica).
In my '01 CV, I run 5w30 QuakerState conventional or 5w30 Motorcraft synthetic blend. It also typically gets a bottle of synthetic Lucas added in and ALWAYS an FL820S.
In my 85 with the 351, I run Quaker State 10w30 in the summer with a bottle of Lucas, and 5w30 with Lucas in the winter.
ALWAYS 3k mile intervals on the 01, and typically around 2k on the 85...it gets driven hard and the Autometer oil press gauge doesn't lie at hot idle.
Personally, I think you guys are a bit nutty for running such long intervals on your oil changes. If your mileage is strictly highway and you're racking up 3k a month then I can see longer intervals...short trip driving (where the oil never reaches full operating temp) and numerous temperature cycles kill oil FAST.
All these modern cars with "oil coolers"...they're actually oil heaters...designed to use coolant to quickly raise the oil to temp and keep it regulated there. Kinda surprised nobody has brought this up yet.'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
Originally posted by gadget73 View PostWhen all else fails, its a safe bet to use the OEM filter. The manufacturer doesn't want warranty work because their own filters are shitty.
Originally posted by mercurygm88 View PostEverything I've ever owned had oil that looked really shitty by the 3000 mile mark, except my Town Car, at 5000 miles the oil still looks pretty damn clean.
Originally posted by sick88tbird View PostIn my '01 CV, I run 5w30 QuakerState conventional or 5w30 Motorcraft synthetic blend. It also typically gets a bottle of synthetic Lucas added in and ALWAYS an FL820S.
We've never owned a car with an oil cooler up until this 454 GMC we bought but I did notice it uses the radiator as a cooler and that thought did cross my mind...1985 LTD Crown Victoria - SOLD
Originally posted by DerekTheGreat View PostI just can't get on the Lucas Mucus train.. Not a fan of their products but I don't have scientific proof that says they do or don't work, just my opinion.
It took awhile for me to get on board with Lucas...I've seen it clean up Diesel engines quite nicely and circle track guys run it...if I'm abusing an engine with sustained RPM(like I do in the 85), it gets the Lucas snot...the synthetic Lucas is actually pretty light and I only really use that in the 01 as a "just in case".'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
Originally posted by sick88tbird View PostPersonally, I think you guys are a bit nutty for running such long intervals on your oil changes. If your mileage is strictly highway and you're racking up 3k a month then I can see longer intervals...short trip driving (where the oil never reaches full operating temp) and numerous temperature cycles kill oil FAST.
As far as the oil "cooler" I've always wanted to bypass the stock unit, and go with a standalone oil to air...just never had the time or inkling to do it...plus like I stated above, I don't really beat on it, so it seems like it would be pretty worthless, especially considering these motors will last for 300K+ with the stock "coolers". Maybe if I was towing or lived in an extremely hot climate2008 Ford CVPI ex Boone County, MO Sheriff
I like the red 'n tacky. I started using it for the tie rod ends on my truck as the one on the driverside especially was getting the grease washed out, red n' tacky solved that problem. At least now when I regrease I don't have a handfull of mud in the joint to get out.
Alex.
