the only window in my car that actually goes down correctly is the front passenger... the back 2 i have to push down and up (you can hear the motors but they dont move when u push the button) ... and my drivers window doesnt make any sound and wont push down or up.... could someone tell me what parts i need to buy to fix all the windows?
1993 marquis drivers window (real quick question)
Window with "no sound" may be motor/regulator/bushings. The others are probably regulators/bushings. They are not like the older ones where bushing/motor replacements do the job. There are videos on YOUTUBE that show how to replace the regulators.
if it won't push down or up, the motor is probably jammed with dead bushings. The cable regulators either work, or the window gradually falls down... unless the guides are a little loose, then the window can come crashing down. Though that's not usually an issue with panthers as much as trucks with the straighter glass.
thats what mine does sly, the drivers front and drivers rear both you can hear the motor trying but the windows dont go up or down when pushing the switch, but as the car sits i notice my windows come down just ever so slightly and i have to pull them back up by hand. I got quoted the other day for $500.00 to have them both done at the same time. I watched the video on how to do it but i cant see myself tearing the window out and remembering all that non-sense, so im more than likely gonna pay to have it done unfortunately.
1992 Mercury Grand Marquis
$7 parts from Advance. I did all four of my windows because, well, all four bushings failed. The bushings are cake, honestly.
They are plastic/nylon, dry out, and fall apart. So the motor turns, but there's no window action going on. Or, you can put in 7/16th ball bearings and never have to do the bushings again.
I should see if I have a spare one laying around to take pics/videos of.
03 Mercury Marauder- 63k
