In the not-so-distant future, I am going to install a dual exhaust on my '05 MGM. I will be cutting off the dual exhaust of a junkyard car and pattern a 2.5" exhaust from it. I know there is a dual exhaust kit from Stainless Systems, but I want my exhaust quiet; with cutouts for those summer days in traffic when I need waking up. I will be installing headers maybe next year. I also know from experience that it's easier to install a full exhaust all at once (easier to lay it all out and fit everything together). My budget is making me do this backwards; so the exhaust will be done first; headers later. With that said, I have one question; what role do those weights on the stock exhaust flanges play? When I do the full exhaust, should I weld those weights onto the new flanges? Kinda silly question, but I figured that they are there for a reason.
Dual Exhaust Conversion
they are there to minimize drone.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Okay. Thanks for the fast response JaywishWish my coworkers were that fast :-/
I am going to install Dynomax 17748 muffs with some resonated exhaust tips that I got back in the '90s. Hopefully it will be quiet with relatively little drone.
JBTW 2.5" might be a bit of overkill. 2.25" if available might be a bit cheaper and easier to work with while providing a great improvement over the stock single and stock duals as well03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
What is the difference between a '98-'02 exhaust and an '03-'11 exhaust? The reason I'm asking is because the '02 CV that I'm pulling the suspension off of has a dual exhaust; unfortunately it's the only Panther in the yard with a dual exhaust. My plan is to cut the exhaust off and use it as a template for the new exhaust. Just wanted to know if they're compatible.
Having tried an ‘07 system under my ‘97, everything seems off. The H-Pipe hit the floorboard and the over axle section seemed way tighter. I’d consider the earlier system to be closer related to Aeros. I’d check H-Pipe year compatibility for determination.
My Cars:
IDK much about exhaust issues, but for me, the extra weight and drag from the weights 'outweighed' any sound benefit. I'll have to wait until I get new exhaust flanges welded on before I know what my car actually sounds like with intake alterations and weight removal without an exhaust leak. A couple of years ago when we still had emissions checks for cars (they stopped in April), I was really blown away by the 'growly/rumbly' sound my car made when I heard the mechanic start it up inside their shop. I haven't been particularly motivated to make it stop sounding like a beast.
When I first got the '86 CV (back in '03) I was still in loud mode. My Malibu had 3 modes; single 3" exhaust with glasspack and hi-flo cat (kinda loud); cutout after the cat (loud); unbolt the exhaust flange at the Y-pipe (after the headers - stoopid loud). I was leaning towards quiet when I did the full exhaust on the '86 CV (back in '07); shorty headers, cat'd H-pipe, and decent mufflers with cutouts after the H-pipe (pretty loud for a lopo). After 2 Rangers, a S-10, and my current '05 MGM; I am liking the OEM quiet mode. That's my goal now when I do the full exhaust on the MGM.
I think the new subframe on 03+ makes the engine position a little different, thus making the exhaust just a little different. I think the splits are 92-97, 98-02, and 03+. Since the Stainless Works complete exhaust systems make the split at 98-02 and 03+... I think my reasoning is logical. The manifold to down pipes and H pipe should be the same 92-02 while the tails is what changes due to the shock placement I think.
^^^Yes. The 98-02 will be much closer to what you need than 03+ but not dead nuts. Patterning after that MAY work out ok but i think the over-axle pipes may need a little tweek. Far as the drone-reducing weights, don't bother. Mufflers will make much more difference in that. I had cheap ebay shorty headers, a mustang off-road pipe with 2 cats welded in, and impala tailpipes with Moroso Spiral Flow mufflers. On a stock lo-po it was pretty mellow and no drone at all.
"Having tried an ‘07 system under my ‘97, everything seems off. The H-Pipe hit the floorboard and the over axle section seemed way tighter. I’d consider the earlier system to be closer related to Aeros. I’d check H-Pipe year compatibility for determination."
You're right the 92-97 system is the same as the 91 and earlier models. You'll see that in the Walker exhaust parts guide.
