Open diff will not come off!!!!
    Trying to remove the diff as we speak. Took out c- clips and bearing retaining arch-things, and pinion bolt. need help asap! I even hooked up a cargo strap and tried to pull it out to no avail. I'm trying to do this tonight, so any help is appreciated immediately!!!!!!
    whoever helps me get this off gets a present at ScottFest10!!!
    08 Lincoln Navigator L - 233k
    03 Mercury Marauder- 63k
    jam a big prybar in the carrier and turn the pinion flange.....that usually helps break them free
      Stupid ? but did you push the axles out of the way?
      1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
        you got the whole pinion bolt out right? They snap sometimes. If the pin in the middle that holds the spider gears came out, you're good.
          He took out the C-clips, and as I remember, you can't get those out without first having the pin out. Correct? I also agree with Pesty - really stupid question, but yeah, did you yank the axle shafts?
          They do come out hard sometimes depending on the number of shims in the housing. More than likely you just haven't pulled hard enough on it yet. Like Scott said, go at it with a prybar and it should come.
            Removed c-clips , axles are out. I used a 5k cargo strap to try and pull it out. I'll try the shims with a prybar or a punch to see if i can get some thing to move.
            I'll try a prybar again.....
            thanks mangs
              Put the trans in neutral, as it sometimes can help it to fall out easier. Not usually an issue, but in a unique circumstance it might.
                Driveshaft is removed
                  got it. Now the spider gears on the trac-loc are being difficult.
                    Everythings good. just having a tarded evening.
                      I'm gonna assume it was a success seeing as I saw the tank roll by as I was pulling out of bob evans.
                        If you in buff and need help, i can stop up and help out givin enough notice.
                          Worst case, hook the driveshaft back up, start the car, put it in drive, and hold it to the floor. It will all come out eventually.
                            I like your thinking.
                            1985 GMC 1500
                              Yeah, everything was good. And i test drove the car for 19 miles before driving to Philly and back over the weekend.
