I do have a rear bar. I didn't measure, but it looks pretty small. The rear anti-sway is adequate, the car doesn't wallow at all. but if I were trying to achieve perfection, it could be a bit stiffer (I know, that's what she said
I probably won't change this unless I need to do something else that involves rear suspension. My question is, if I went to a larger diameter rear bar on this car, would I need to increase the front sway bar diameter as well to keep the handling "balanced", or is the relationship not anywhere near that critical? Thanks.
-VG
-VG
