Does anyone no where theres a airbag trouble codes for a 92 mine blinks 3,4,5,or 6 times
Air bag light
This is a sticky topic.
08 Lincoln Navigator L - 233k
03 Mercury Marauder- 63k
Those are engine codes. Airbag codes are one of two different code lists. 92 ought to have 2 digit codes:
| Code | Description | Pinpoint Test |
| No Indicator | Inoperative air bag indicator circuit | A |
| Continuous Indicator | Diagnostic monitor disconnected or inoperative | B |
| 12 | Loss of battery power to air bag firing circuit | C |
| 13 | Front crash sensor or air bag circuit shorted to ground | D |
| 21 | LH B-Pillar safing sensor not mounted to vehicle properly | E |
| 22 | Safing sensor shorted or stuck closed | F |
| 23 | Open connection in safing sensor feed circuit | G |
| 24 | Safing sensor diagnostic circuit open | H |
| 31 | All system air bag(s) open | I |
| 32 | High resistance or open circuit in driver air bag circuit | J |
| 33 | High resistance or open circuit in passenger air bag circuit | K |
| 34 | Low resistance in driver air bag circuit | L |
| 41 | Open connection in forward crash sensor circuit | M |
| 44 | RH front crash sensor not mounted to vehicle properly | N |
| 45 | Center front sensor not mounted to vehicle properly | O |
| 46 | LH front crash sensor not mounted to vehicle properly | P |
| 51 | Diagnostic monitor internal thermal fuse open | Q |
| 52 | Backup power supply fault | R |
| 53 | Diagnostic monitor internal fault | S |
| 99(1) | All crash sensors disconnected | T |
If yours is single digit codes:
Code Component/Fault Description
No Air Bag Indicator - Inoperative Indicator Circuit
2 All Primary Crash Sensor Disconnected
3 Air Bag Deployment Circuit - Low Battery Voltage or Low Backup Power Supply Voltage.
4 Safing Sensor - Diagnostic Circuit Open or Low Primary Crash Sensor Resistance
5 Air Bag Circuit or Crash Sensor Circuit- Shorted to Ground
6 Driver Side Air Bag Circuit- High Resistance or Open
7 Passenger Side Air Bag Circuit - High Resistance or Open
8 Primary Crash Sensor Circuit - Not Mounted to Vehicle Properly.
9 Primary Crash Sensor Circuit - Open or High Resistance
10 Diagnostic Monitor Internal Thermal Fuse - Open due to Intermittent Short to Ground
from http://www.veryuseful.com/mustang/tech/airBag/86 Lincoln Town Car (Galactica).
I think its 34- Low resistance in driver air bag circuit cause i counted 6 first a start up then 5 the cositently 3,4 i dont really know where to start i never messed with airbags thanks for the list tho much apreciated1999 Ford Explorer
1992 Mercury Grand Marquis
