what is the most power stock 302 every built
    Just was researching and I couldnt find what year or car had it
    just wondering if you guys knew
    Stock 302 windsor is probably the 93 Cobra, but with a different cam and headers, the Explorer 302 is higher, because the heads and intake are better.
      I think the 93 cobra had 240 hp or somethign like that. maybe a early 70's boss 302, but then again thats not a true 302 since it has cleveland heads.
        The older mustangs (ones not using the BOSS) didn't seem to use the Windsor 302, but instead used the 289. Those went into 300hp+ arena.
          Teh boss had 290hp gross. Ratings from '72+ are net, which is more accuate (aka the same engine would be rated lower). There is also the Tunnel Port 302, but they were never installed in a factory produced car. The Tunnel Port basically blew up a lot because it had to rev to 7500+ to make power. Wee!
          The 302 was available from late '68 to 1995 in Mustangs, except for '74 when there was no V8 and maybe 1980 or '81 when the 255 V8 temporarily was the top engine.
          My bet is on the '93 Cobra for the most Ford Produced horsepower.
            302's were produced until 2001
              I would say the old Shelby Mustangs. The Boss 302 was under rated pull there rev control box and they would fly.
                so the consensous is a 93 Cobra now what did it have that made it so powerful and where cn get the parts for cheap im craz i know i said cheap but like for a grand i m willing to puti no the engine bay
                  For one thing, 240hp is sad. It's kind of pathetic that an engine with such a reputation as a performer never made any real power numbers from the factory. HO parts are cheap. GT40 parts are moderately priced. The Cobra motor has Cobra upper intake, GT40 lower intake, and GT40 heads. The Cobra motor also comes factory with Crane 1.7 ratio aluminum roller rockers, where the Explorer come with stock stamped steel rockers. The Explorer motor has GT40 upper and lower intake, with GT40P heads (which are a little better). With the right cam and exhaust, the Explorer motor can put out 300hp without any other mods.
                    thats wat i thought so is a cobra intake better or a gt40 intake
                    now wat type of came should i get and rockers and springs should i get also looking to make 300hp or more and 300ftlbs of torque
                      P heads are over rated. The 40s are a better choice.
                        Go with GT40 upper and lower intakes, and GT40 heads. If you're gonna rebuild the engine, get a larger camshaft. And if you haven't, redo the exhaust. After that you should get some great results.
                          This has been discused in great detail many times. maybe with money spend on porting and other stuff GT40s are better than the P heads, but stock to stock GT40P heads are better and have better flow numbers.
                            Just go to your local boneyard,get a cheap $500 explorer 302,Throw in a HO cam,good valve springs,1.7RR's,and your ready to rock.
                              If you ever want to replace your engine with a real ford replacement they have very powerful crate engines and one of them is the GT40 302 and a similar one the 347 (not the one we are getting). I have seen a build up of the mustang HO 5.0 FI STOCK that pushed the mustang into 10's with a new trans in muscle mustangs and fast fords magazine
