Im starting an engine build with a nother 302 i have that i want to drop in the merc next spring, i have a set of 351 windsor heads, look like old ones, and they take the bigger spark plugs, some one told me that if i put them on a 302 it will boost the compression up,, just wanted to know how they differ from the stock 302 heads and how much of a differnce they will make,,
351 windsor heads higher compression?
assuming 300hp with a CR of 9:1, jumping up to 12:1 will only give you 23HP and be at or very easily past the limit of pump gas.http://secondhandracing.com/Home.aspx
Figured out all this a while back. The comprersion is under 10 to one. 9.5 or so. One thig is pushrod length. Due to deck height differances some situatios might require slitly longer than stoc 5.0 pushrods. Might get away with factory rockers and stock or mild cams. If your running full roller rockers best to check valve tip contact patch. Push rods are al ways the last part I purchase after building an engine.Scars are tatoos of the fearless
gonna need special head bolts to use 351w heads on a 302.........351w panther heads were poo........87 up trucks are e7's
You can use regular 302 head bolts, but you will need the reducer washers.Originally posted by lincolnmaniagonna need special head bolts to use 351w heads on a 302.........351w panther heads were poo........87 up trucks are e7'shttp://secondhandracing.com/Home.aspx
If its got the big plugs, you're talking 70s or older model heads. Best hope is probably a C9, or D0 casting number. They'll probably raise the compression marginally, but it won't be a huge amount. It really depends on the exact head though. Different castings had different size combustion chambers. Just because its a 351 head doesn't necessarily mean higher compression ratio.86 Lincoln Town Car (Galactica).
You want to look for the following castings: C9OE-B, C9OE-D, D0OE-C, D0OE-G, D0OZ-C, D5TE-EB.
All of those still had the larger valves, with 60.4cc combustion chambers. Later than that they refrained to the 302 valves and 69cc combustion chambers, basically the same as a 302 head.1990 Country Squire - under restoration
Working with half my brain tied behind my back just to make it fair- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
What kind of C.R. would you be looking at with that size chamber?Originally posted by TiggieAll of those still had the larger valves, with 60.4cc combustion chambers.
On a stock lo-po to '85, you'd be going from an 8.4 to a 9.3 or so. But piston choice will make the difference. On a 351W, it be going to about a 9.2 or so.Originally posted by Nathan in MNWhat kind of C.R. would you be looking at with that size chamber?1990 Country Squire - under restoration
Would a 9.4:1 C.R. require premium fuel?Originally posted by TiggieOn a stock lo-po to '85, you'd be going from an 8.4 to a 9.3 or so. But piston choice will make the difference. On a 351W, it be going to about a 9.2 or so.Nick
88 Colony Park LS
- 7373
- Big Rapids, MI
- Send PM
Most likely not. Obviously there's a lot of factors, but you're most likely safe on the cheap stuff up to around 10:1.
I was running about 9.4, 16deg of timing and a 75 shot on 87 octane.Originally posted by 88MercWagonWould a 9.4:1 C.R. require premium fuel?
Now im running even less compression (67cc heads vs the 64cc E7s) a little less timing and a 125 shot and run 93.http://secondhandracing.com/Home.aspx
