I have had a lot of bad luck lately, and my only really good car was crushed by a tree in a tornado, but it was all good because I had the wagon. Anyway, a week before my second daughter was born the tranny went out in it and it only had 1 and 2. So I pulled the good motor out of my crushed sedan and the good tranny with it and swapped it into the wagon, but beforehand I swapped in the ho cam and 19 lb injectors, and an 88 mark 7 computer. I already had done the heads, intakes, and headers prior to my sedan getting smashed, so basically i just finished up the ho conversion, because I already had the parts lying around. Problem is when i got it all together again, it will not start.
I changed to the ho firing order, i even tried switching it 180 degrees just in case. I have fuel pressure of 40 psi on the rail or greater. I have spark. the engine had no running problems before or after the car being smashed. The cam timing marks were definitely lined up correctly when i installed it. It doesn't even act like it is trying to start but it lopes every couple times around like maybe 1 or 2 cyls are hitting. no backfires, or anything.
the cam was from a 94 mustang, the only markings were ZE 23:21 4-24-94. Is this maybe a cam with a different firing order?
I have no idea what to do next, I need any suggestions that anyone has to offer, I work 24 hour shifts 60 miles from home and I go to work on saturday, I don't want to leave my wife and kids home alone in the middle of nowhere with no car so i hope to have this thing running before saturday.
