Looks like the adjustable fuel pressure regulator did it's job. I backed the pressure at idle w/vacuum to 30psi. Car does not stall anymore on decel. Finally have decent drivability with great performance. Off idle response is better also. Car should be a friggin beast with a tune. Milage will probably go up a bit also, and I was getting 22 before!
Yay for band-aids...
22 mpg
30 psi w/vaccum is with in factory spec and usually what my cars run.
this makes me wonder what the fuel pressure was with the stock, non adjustable regulator?2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Cool, glad it's fixed. Cars with drivability problems always take all the fun out of it.1990 Country Squire - under restoration
Hm maybe thats part of why my car runs too rich. I think my idle psi is about 32-33.86 Lincoln Town Car (Galactica).
Should be 39psi with the vacuum OFF, that's the stock pressure the ECM is calibrated for.Originally posted by gadget73Hm maybe thats part of why my car runs too rich. I think my idle psi is about 32-33.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
I backed off the fuel pressure about 1/2 turn and it stopped the wandering idle. Not sure what thats set to since I don't have a pressure gauge here. I do believe it was set to 40 psi with no vacuum, and if memory serves it had about a 6 psi swing, putting it around 33-34 psi with vacuum. Exhaust still stinks of richness but not quite as much. There is a lot wrong with my car, but I'm not overly concerned. Heads are to be shipped out Monday and if I can get all my stuff together, head swap in the next couple weeks will be happening.86 Lincoln Town Car (Galactica).
