Originally posted by ltdcrwnvic
View Post
the 02 sensors need to be heated for proper operation, as such they have heaters built into them (notice the 3 wires). the heaters have grounds, which need to be connected for the heater circuit to work. heater ground for the drivers side sensor is mounted to the rear intake stud on the drivers side. ground on the passenger side is a bolt in the rear of the passenger side head.
obviously the wires should be routed away from the hot exhaust pipe or manifold to keep them from burning.
