You know, if you go with a roller block (can't put a roller cam in your '82 block without hassles), I'm really, really liking the cam I put in the Explorer motor I built for my '87. It's a high-lift, short-duration grind that makes lots of torque at low RPM. It's rated to float the valves by about 5500 (1500rpm higher than the stock tranny shifts anyway), but on the virtual dyno it produces a pretty flat torque curve at about 370-plus lb-ft. http://www.cranecams.com/index.php?s...11&lvl=2&prt=5 There are also some similarly-performing flat-tappet grinds such as Crane's PN 364211 if you end up without a roller block.
For carb and intake I like Edelbrock; their PN 2121 "Performer" intake is said to be good for at least 300hp, and you can't really go wrong with either the #1403 (500cfm) or #1406 (600cfm) Performer-series carburetors. They work well, and even a boneheaded home mechanic like me can learn to tune them. And don't overlook the possibility of getting an old factory 4V manifold if power over 4500rpm isn't important. For ignition, I'm tentatively assuming your car has Duraspark-II ignition from the factory; if so, that works just fine for mild builds, especially with a nicer coil and wires, just as long as it's not one of the specimens that eats ignition modules for lunch. And the Duraspark distributor works well with either stock or aftermarket ignitions, just gotta make sure the gear is compatible with your cam type (iron for flat-tappet, steel for roller); we can point you to some threads about turning up the heat on the mechanical advance.
