what about the Capri?
5.0 HO VS NON-HO Question
Im more interested in the roller block whether its an Ho or not. I know I can get a general idea by looking at the plenum to determin "HO or not." SO, 1986 and up have roller or "roller compatible" blocks.Vehicle: 1965 Pontiac Catalina (fastback 2+2)
Chasis: 1982 Ford LTD Country Squire
Drivetrain: 302 V8 carb, AOD, 8.8 with 3.08 gears.
Big Brake swap and front suspension completed.
Were there any variations in the chamber size of different-application E7TE heads? Just wondering, since for example F1ZE GT40 Cobra heads are supposed to have smaller chambers than the F3ZE GT40 Explorer heads like mrltd and I have - though, granted, those are kind of a different casting number.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 86VickyLX View Postwhat about the Capri?86 Lincoln Town Car (Galactica).
Originally posted by 1987cp View PostWere there any variations in the chamber size of different-application E7TE heads? Just wondering, since for example F1ZE GT40 Cobra heads are supposed to have smaller chambers than the F3ZE GT40 Explorer heads like mrltd and I have - though, granted, those are kind of a different casting number.86 Lincoln Town Car (Galactica).
Originally posted by lincolnmania View Postdid you look for 88-92 lincoln mark7's? most commonly found place of nice running not beat on ho motor.......usually the air suspension or the brakes are bad and they get junkedsigpic
1986 Grand Marquis LS 2 Door
3800-3900 lbs for a mark vii, basically the same as a Crown Vic. The air suspension is so painfully simple and easy to deal with, its really a shame that people get priced right out of the shop for that stuff. I've heard 3-4 grand to rebuild it. You can buy every part for the thing for about $700 and install it yourself, its quite simple. Takes like 15 minutes to change an air spring. Its way easier than coils. bags are 92 bucks each, solenoids are 22 each, compressor assembly is 171, and 20 bucks for the noise isolation donuts. Its also rare that every single part is shot at the same time.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postnot that I'm aware of. I suppose its possible to see slight combustion chamber differences year to year and casting to casting, but the part number stayed the same so no major revisions. There may be some suffix for the 351 version that got the larger bolt holes, but I don't know.
All GT40 heads were initially cast/machined with the same chamber size. The heads which ended up on a Mustang Cobra engine got additional machining to reduce the chamber size. All E7TE heads had the same chamber. Some merely had the head bolt holes drilled for 1/2" if they ended up on a 351W. The Ford part number is different, but the same casting number is used.
Originally posted by gadget73 View Post3800-3900 lbs for a mark vii, basically the same as a Crown Vic. The air suspension is so painfully simple and easy to deal with, its really a shame that people get priced right out of the shop for that stuff. I've heard 3-4 grand to rebuild it. You can buy every part for the thing for about $700 and install it yourself, its quite simple. Takes like 15 minutes to change an air spring. Its way easier than coils. bags are 92 bucks each, solenoids are 22 each, compressor assembly is 171, and 20 bucks for the noise isolation donuts. Its also rare that every single part is shot at the same time.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostVery interesting ........ so there's zero harm in buying a Mark VII with shot air suspension as long as I budget in an extra $700 ......... hmmmmmmmmm..........sigpic
