Okay Dokie
you can use the same gasket in both spots. I think there might be a specific gasket with a screen thing that goes between the cooler and the intake, but its not real important. Just get 2 egr valve gaskets and you should be fine. Or just use one and get rid of the cooler. Same difference.
Originally posted by 86VickyLX View PostNot really, I used it for the IAC gasket on my car cause no one had it. I used a hammer and punched it all out. it's almost like that notebook paper that you can rip that fringe stuff off cause it has those liitle cuts in it.
Leave a comment:
Originally posted by 1987cp View PostAnother universal option might be to buy a roll gasket material, often available at local hardware stores, and just cut what you need .... though I'll admit that my experience is that the cutting process is mega-tedious and tends to result in forceful hair removal.
Leave a comment:
Ugha hehe, I imagine!. Well, i went to Napa. And they didnt have one either But I got them to order me one it will be in tomarowwoohoo.
Ofc, i got in a 15 min argument that the two he had listed on his compute where actually the same thing sept one had a nice neat little screen to keep the crap from being cloged. and he was saying noooo, there for difrent applications. UGHA.. Demn part's guys. I told him finally though, i said "Look Ill pay you right now to order that 2.00 one.
And that shut his argument up...
Im surrounded by idiots!
Thank's 87cphehe
And Thanks Gadget mang for the info Earler.
Leave a comment:
If the situation for getting the correct gasket is that bad, really, I'd just get a tube of Ultra Copper sealant and say screw it. Works as good as Ultra Black on normal mating surfaces, and it's very, very unlikely to be harmed by the heat level it'll see at the EGR valve.
Another universal option might be to buy a roll gasket material, often available at local hardware stores, and just cut what you need .... though I'll admit that my experience is that the cutting process is mega-tedious and tends to result in forceful hair removal. :p
Leave a comment:
Napa only list the one for Exhaust Gas Recirculation (EGR) Valve Mounting Gasket
No cooler one :-? Can i just use two of these? since there about the same size and do have the same bolt pattern?
Leave a comment:
Bit of a rant.
Ok, so anyways i went to my part's house ( Local ) ( Same place i bought the bloody EGR sensor..) Anyways, he said he didnt have them and would half to order it. Well im still waiting for an oversize plug to come in that he ordered a year ago!.
I really think ima quit doing all bizness with him, even fuel.
Anyways, next stop later will be Napa for them gaskets. At least ill know if i order it, it will come the next bloody day!. hehehe.
Not really to bad of a rant now was it?
O, and this is what i told him i needed.. Not sure if i worded it right myself..
"Need a gasket for the egr - valve ( - ='s to the) and from the egr cooler - spacer."
That is correct isnt it?
Leave a comment:
Originally posted by gadget73 View Postdont think so. the egr gasket is a special graphite material because it gets pretty hot.
Leave a comment:
kk hehe, ill trow that right out of my head then!
Im just hoping this parts guy is gonna be smart enuff to figure out what im talking about.. he is a bit of a tard some times. and a prick to boot.
Ima tell him i need the gasket for the egr valve and the cooler and the space.Hopefully he will be able to understand the words coming out of my mouth.
Thanks again mang
Leave a comment:
Leave a comment:
Well i seperated the color as well hehe.
Question. Will liquid Gasket work allright with this? Cause i think i actualy have some still from my oil pan leak..
Leave a comment:
you only need the gasket between the egr valve and the cooler if thats all that was seperated.
Leave a comment:
:-? Im confused now... hehe.
Is it two or three?
I know the only thing's which where separated where the water colore thing and the egr thingy hehe ( Looks like a speaker.)
So that mean i need just the two?
Leave a comment:
on the cfi i think there is one between the valve and the cooler thing, and another between the cooler and the spacer under the cfi unit itself. not all cars have the cooler thing.
Leave a comment:
Three gaskets total on the EGR spacer, I think - one on the EGR valve flange, one on the intake manifold side, and one on the carb/throttle body side.
Leave a comment:
Leave a comment:
