1982 Mercury Marquis Brougham
302ci
AOD
Edelbrock 1403 carb
Edelbrock Performer intake manifold
Hey guys.
Can someone please address the issue of AOD pressure at constant speed.
I installed the Lokar:
1) SRK-4000 bracket & springs,
2) TC-1000HT throttle cable,
3) KD-2AODHT kickdown cable.
I removed the slack from the throttle cable and then used the "special tool" on the kickdown cable. In neutral, my AOD is 35 psi with special tool in place. However, it drops to 0 psi when I remove the tool. Is this right or wrong? Psi increase looks good under acceleration (both light and hard), but again drops to 0 when I let up on the gas pedal to maintain a constant speed. Please explain! Is this right or wrong? I don't want to burn up my transmission.
302ci
AOD
Edelbrock 1403 carb
Hey guys.
