I got the mounts for the cage done today.. hopefully I can get the two remaining parts of the cage spotwelded tommorow... My welder has been really busy lately on projects away from his shop... So I have to catch him when I can... Then I can bolt everything in the car.... and get the rest of the trim in.
The hole is for the seatbelt bolt to go thru... which will mount the cage mount to the "B" pillar....
The second hole...^^
is for a second bolt I figured I could install to make it stronger... There is a trim screw hole there... So I am going to drill it out a little bit, then put a 5/16 thread cutting bolt in...
reminder of what the cage looks like...
After the cage.. on to wiring all the equipment! Tom...
