Recently my wagon has been missing (i think) while driving down the road. When i drive it there is a slight kick or buck it goes away if i downshift and rev the engine. I'm thinking it's an ignition issue maybe just bad wires. Anyone else had this happen? Seems to happen when its under load climbing a hill or something. I hope it's not a trans issue.
Engine Missing
bad plug wire....bad spark plugs....when was your last tune-up? clogged fuel filter....My old 87 Mercury Grand Marquis-RIP- http://www.cardomain.com/ride/3016650
Now Driving A
1999 Mercury Mountaineer with the 5.0 V8 its also AWD..... Atleast I'm keeping it in the Mercury family right?
not sure about the code i would think so haft to ask gadget or lincomain.... they would kno bestMy old 87 Mercury Grand Marquis-RIP- http://www.cardomain.com/ride/3016650
Now Driving A
give it a full tune up with quality parts......check it for ecm codes
i've had good luck with the frpp wires......others have not.....for 40 bucks you cant go wrong
They are quite affordable, I'm not really too concerned about price, i'd like to put something on there that will last another 100,000 that i don't have to worry about.
Basically, if something else goes wrong down the road i don't want to have to think to myself did those ignition wires i put on fail again.
Haha sometimes thats the easiest route!!
I ran the code reader on it tonight and it threw one code.
code 34 on the continous test. Key on Car off.
Egr stuff, i just replaced a bunch of egr valves 2 years ago so I'm hoping this code is kinda just related to the missing.
Maybe pull the injectors and see what kind of shape they're in....if they're all messed up it could lead to missing.Originally posted by gadget73There is nothing more permanent than a temporary fix.
vacuum leak...'88 Colony Park, white with wood grain contact paper, K code axle, hose pliers on heater hoses, factory duals, big plans in the future...
'83 Toyota 4x4, 31x10.50 15, could use a new carb, custom humidifying holes in the roof, mud based paint...
yes they are good wires mang
