Well, I FINNALLY got a chance to work on the car today! No erands to run, nothing else going on.. it hit me, WORK on the car!!! So I got the cage mounts in, the seatbelts, and the "b" pillar trim before the "mosquito Air Force" showed up.... (They show up at dusk everyday!!)
Then a friend of mine came by and adjusted the carb float on my lawnmower... IT RUNS!!!! It hasn't been running for about 3 months... it is a real bitch to "mow" the lawn with the weed eater!!!
Anyway.. here are the pictures... tommorow the rest of the trim goes back in... then the sirens etc... then all the rest of the interior.... Getting closer!!!
Also you can see how nice the seatbelts cleaned up.. they are like brand new... The drivers side had a HUGE black grease spot right below the buckle right where you could see it when it was retracted...
I soaked them in clothes detergent and some clorox II... set the retractors on the side of the sink, pulled the belt way out, and put clothespins on the belt to hold it out.. then let them soak in the sink... When I came back about 3 hours later... the water was a dark yellow.... I think someone used to smoke in the car... (Nicotine?) Then I scrubbed them with a scrub brush and let them dry.. they came out great!!!
(I need to do the '91's now!)
Tom...
Tom...
