I've got the loveboat more or less straightened out. I reset the timing, this time with the spout connector out, to 10 degrees. Greatly improved power. Good acceleration. However, at low RPM with a load (uphill) in OD or high gear, there is a sputter even at steady rpm. I can't really hear it, but I can feel it. Like the engine is missing a little built, it's not a steady sputter. When the tranny kicks down and the motor spins up, it goes away. The condition worsens the longer the motor has run. (less bad cool, worse hot)
I was thinking it was possibly pinging, so I retarded the timing to 9 degrees and put in a tank of 93 Octane gas.
It is still there, and there is some roughness and missing to the idle once the engine is warm.
My compression is about 165 in all the holes, which when divided by atmospheric pressure of 14.7 equals a compression ration of about 11.2:1.
Pretty high.
I'm thinking maybe with all the HO mods, the old 14 lb injectors can't keep up? Just a thought.
To refresh anyone's memory, I did the HO conversion with the exception of the cam, injectors, and computer.
The car is very driveable. I took it to PA and back (4 hours). I'm thinking maybe I should buy a Kirban adjustable fuel pressure regulator and bump up the pressure a little to feed the higher compression holes.
Pretty high.
