If I have to hit the trunk release button two or three times before it pops open, could that solenoid be wearing down? Is it even available anymore?
Trunk release solenoid bad?
F0AZ-5443200-A is the part number for the latch assy. I can't say 100% by the description if that included the solenoid, but it probably does, as I haven't been able to find it seperate. Your friendly Ford parts person should be able to find out. 92 has a different part number so it probably is not available but it is worth a try.
PartsVoice showed a couple of those assemblies in stock at local dealerships. I might price one tomorrow and see if it is worth a shot.
When I hit the button, I hear it click, but it takes a couple times to pop it open--so I'm in the same boat as you. It's not a big deal, but I would prefer it to work like it did when it left the factory!
trunk lock
Stu...
Try a little WD-40???? maybe it is just sticking a little....
yes what tom said.........stop replacing parts stu!
clean the connections and lube it up with some sort of weasel piss......wd 40, blaster, liquid wrench, the 80 cent a can wally world stuff, bacon grease, vegtable oil, ky jelly.......now i'm just being silly......i will stop now
scott
on a separate but similar issue...
I couldn't get my hood to latch closed to save my life. Adjusted the latch up and down, left and right, moved the stops up and down... had to slam the crap out of it.
Then I thought, WD-40...
Worked like a charm. I guess it just needed some lubin...
We all could use some lubin sometimes... :banana:2000 Grand Marquis LS
Mercury Owners Group member
Stu...
Did it work???
Originally posted by StuIt gets shorter and my finger feels pressure? :drug:Originally posted by Pimp Hard Or Bustwhat happens if you hold the button down
LMAO ROF2000 Grand Marquis LS
