I've never had much luck snugging down valve cover bolts with petrified gaskets. Usually the cork gets rock hard, and making the bolts tighter, even to the point that they are barely snug, cracks the gasket and increases the leakage. New gaskets are really the only way to fix that problem.
Valve Cover Gasket Question...
So I tightened the valve cover bolts today and I did.. They were so loose on the passenger side. However I noticed the oil is coming from the back of the engine. It's like a steady stream especially after a little bit of driving. All dripping from the back of the engine. I have gotten under there to inspect where it's actually coming from.. Any pointers? Also thanks for all the info! I'm definitely going to get permadry plus gaskets from summit racing. I'm a little weary of buying a gasket online, but I want the steel implanted gaskets. Also before I drive it as my daily, I'm going to replace all my radiator hoses. That bottom one is about to crack and burst. So it makes me nervous. The marvel mystery oil made the tapping vanish. I had forgotten why I loved that stuff so. I plan on flushing the radiator, replacing the hoses, changing out the gaskets my car needs(if you guys can help me with the reason it leaks from the back of the engineand I had posted earlier about my brakes having no pressure, but perfectly able to stop and full brake fluid. Well the more I drive the more the pressure comes back. Weird right? Anyways thanks again!
"Charleston" the 1987 Mercury Grand Marquis LS sedan
The screen under your pcv is more than likely clogged which caused the rear lower intake gasket to blow out from excess pressure. So get a new pcv and the screen that goes under it, all your intake gaskets, and while you have the intake off your might as well replace all the vacuum lines.
'90 LX 5.0 mustang
Big plans
Not really. If you really plan on keeping the car for awhile, you may as well do the lower intake gaskets while your at it.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Originally posted by tyler_hubbard2003 View PostOh okay, it's frustrating though! If I replace that and it still leaks what else could it be? Any other gasket it could be?
Originally posted by 86VickyLX View PostOnce you replace that, there's nothing else it could be leaking from there. Unless the castings themselves are cracked which I highly doubt."Charleston" the 1987 Mercury Grand Marquis LS sedan
Originally posted by tyler_hubbard2003 View Postokay! so pcv valve, valve cover gaskets, lower intake manifold gaskets.. awesome! Thanks guys
As long as you change the oil after you do everything else.
Also--I don't know what the guy above is thinking, but cork=bad.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Originally posted by 91waggin View PostAs long as you change the oil after you do everything else.86 Lincoln Town Car (Galactica).
Originally posted by ford man View PostGet the rubber ones damn. He ALREADY said he was getting the high tech permadrys. I don't think you need 30 dollar valve cover gaskets but whatever. Or just get some regular rubber ones, I don't care.2012 Mazda5 Touring | Finally working on the LTD again!
