Wow nice low miles! Are you planning on keeping it for the long haul? If so you're a lot closer to the timing chain with the water pump off. It can be intimitating to keep growing the job though.
Perhaps go ahead and pull the pump. Take a look at the timing chain cover. If it seems managable and the water pump bolts are clean you may decide to do it. Or not.
Good luck.
Pete
Good luck.
Pete
