Gadget73 has a good point on this starting issue. Give'er a shot of ether and see if she fires off. I didn't catch the year and engine configuration of your Panther. Might be vapor locking the fuel system although is not a common issue with high pressure fuel injected systems. I once had an intermittent problem on one of my CVPIs. Same issue, wouldn't fire after being driven 5 or 10 miles. After you had the hood up for a while, she'd fire right up and you could get it home.....it did run a bit weak though. I placed a small ice bag on the ignition module (fender mounted on the 88 CVPI) and tied it to the cable wiring so it wouldn't blow off. I proved the ignition module bad multiple times with the ice bag before spending the dough to fix it. After that, I always carried a spare ignition module.
wont start hot
So when it is hot, no spark?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
So the engine won't crank with the key, but if you jump the relay it cranks and starts? The only thing between the starter relay and the ignition switch is the neutral safety switch in the transmission and the wiring harness connectors. Might be worth checking that connector out where it plugs in behind the engine. I've seen those crust up before and cause a no-crank condition.86 Lincoln Town Car (Galactica).
power in START on the ignition switch is probably not making proper contact. Check the wires to make sure one didn't get pushed out when you installed the new switch. If the wires are all good there, you may have to trace that one out and make sure it's in one piece all the way.
yeah, sounds like its not getting start power to the TFI module. There are two power feeds in, run and start. Check the wiring on the start side of it. I'd wager you'll find when cranking, it does not get power like it ought to.86 Lincoln Town Car (Galactica).
After you jump the starter relay the car runs on it's own after the jumper is removed?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
It is in the engine compartment in 89. In the evtm there is a page just after the diagram you posted which has a section called component location. It will refer you to a diagram for fuse link M.
Does the engine run after you remove the jump you make to start it?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
It sounds like the map is broken or not connected electrically and or the vac to map is NG.
A big vac leak?
You have an HO or lopo in there, which ecm?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
