wont start hot
    wont start hot
    what could cause my car to not start when hot?car starts right up in the morning when i get to work or any drive it just cranks
    TFI module comes to mind. Could be other reasons though.
    Vic
      What he said. Sounds like heat soaking to me. TFI gets too hot, and stops working until it cools down.
        I didn't know enough at the time but my 89 did the same thing last year, but knowing a little more now I think it was my warning that the TFI was going bad. Eventually what ended up happening is the TFI module finally crapped out on me while I was parking my car after work. I wasn't quite all the way into my spot and it just died like someone flipped a switch. Tried to start it a couple of times and it would start for a second and die so I figured it was a fuel issue. After ruling that out I found I had no spark, and with the help of my dad and another friend figured it out.
        Luckily I was just getting home for work so I wasn't stranded, but the TFI module can seemingly up and die with little warning.
        Vic
          Sometimes that is a sign of dirty or loose battery cable or cables at the ground connection or at the starter. Or a weak, on the way out starter.
            thermal lockout on the starter if it won't turn over when hot. New starter.
              If it cranks but doesn't want to start, and the TFI and pickup check out, try the ECT or ACT. Usually even when bad, the car will start but it might have a hard time getting going.
                i think my PIP SENSOR is going.so im gonna change it every thing else checks out. http://sbftech.com/index.php/topic,28934.0.html
                  ECT, ACT ?
                  The abbreviation portion of my brain has been failing lately.
                    Engine Coolant Temp
                    Air Charge Temp
                      Thanks
                        put pip sensor in distributor also painted it
                          PIP SENSOR, TFI, ECT, ACT, coil check out.get code 11 koeo koer 44 33 94.got fuel and spark.it starts cold but after driving and gets hotand try to restart it just cranks over im lost on this so any more ideas would help
                          thanks
                            44 and 94 are from the smog pump, 33 is EGR. if you removed those parts, that will be why. Not related to the no-start though.
                            It has fuel and spark even when it won't light off? Is the fuel pressure good ? Will it kick off if you give it a snort of starting fluid?
                              If you need a pressure gauge let me know.
