Ok, so, I've done a tune up in the past few months - new plugs, wires, cap, rotor, fuel and air filters, PCV valve and screen.
I've also recently replaced the battery.
I have noticed in recent weeks an odd stumbling that happens sometimes at light throttle, very light throttle, then goes away. At first I thought it was when the car was cold, but it seems that it almost always happens about 2 minutes after first starting the car, then goes away shortly thereafter, regardless of temperature outside. Even if the car's not fully cooled off, and I start and drive it again, it happens.
Today, I was at my son's birthday party at his mother's house. She lives about 20 miles from me. Was there for about 3 hours, then went to leave.
I started the car, it idled perfectly for 10 seconds or so, then cut out.
It would not restart. It'll crank eagerly, but just won't catch.
I checked at the schrader valve at the fuel line underhood, and the resulting spray of fuel on my hand indicates plenty of pressure.
I am guessing it has to be the coil or the ignition module. Both, as far as I know, are the factory original parts, with 26 years and 111,000 miles on them. I figure I can confirm a no-spark situation if I attach my timing light and get nothing while cranking, right?
Am I going down the right track? Or is something else likely the culprit?
If it is the coil or rotor, which parts stores' brands would be better to go with, or which to avoid? Napa, Autozone, Advance, and Pep Boys are all close to me.
Thanks in advance - gotta get this thing up and running to get to work Monday!
