There is another valve in the general area plumbed into the cruise control. Its right above the brake pedal and needs to be pushed in fully when the brake pedal is up. It also needs to hold vacuum. if it leaks badly, the cruise won't operate. If it leaks somewhat, the cruise surges annoyingly.
Did I mention that my car is angry at me? Vacuum leak from gear selector....
Originally posted by gadget73 View Postby actuator, you mean the vacuum can on the parking brake assembly that actually does the release work, right?
Well, confirmed both with the location of the hissing sound when the car was running, then with a vacuum gauge.
The horseshoe shaped valve is the source of the vacuum leak - the actuator that releases the brake does not leak vacuum. Ordered the part from ye local Autozone.1987 Ford LTD Crown Victoria 2-door Coupe - perpetually "sort of" for sale...
Black with Red cloth (velour?) interior.
Purchased on 10/10/2008, with only 70,386 original miles, and only ONE previous owner.
Reader's Ride post, First pic with "new" rims, Other pics with "new" rims
That's a tricky little bastard to replace. I believe that if you start the screws in, then cut the slots on the switch open you can just slide it in and tighten the screws down. That makes it much easier.2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
I used my snakedriver to get that damn thing replaced on my 88... but then the servo died so meh. it's plugged now.
I didn't realize Autozone would have the vacuum release switch. I ordered mine off Rockauto.com--a good place for random parts. Not gonna lie . . . after getting in a weird ass yoga position under my dash, I didn't have the patience to deal with the r/r, so I gave the switch to my tire shop when they put new whitewalls on, and they changed it out in 5 minutes for free.
Originally posted by gadget73 View PostThere is another valve in the general area plumbed into the cruise control. Its right above the brake pedal and needs to be pushed in fully when the brake pedal is up. It also needs to hold vacuum. if it leaks badly, the cruise won't operate. If it leaks somewhat, the cruise surges annoyingly.
yeah I plugged the one on my Mark VII too. Same reason. I would prefer it be there as an "oh shit" device to make sure the cruise shuts off but its not to be found really.86 Lincoln Town Car (Galactica).
all fine and dandy in theory, except when something gets put in the trunk to short out the brake lights, the fuse pops, and suddenly you're doing 65 heading into a toll booth where you have to stop with the throttle shoving downward the more you push on the brake pedal. BTDT, which is why I would really prefer to have it functional.86 Lincoln Town Car (Galactica).
Are you serious?!?!?!?!?
Originally posted by sly View Post+1 inside. the screws are hex drive 7/32 or 9/32 (can't remember which off the top of my head). The stuff still works in my Mark and Vic, but the 88... I got the last actuator in dealer stock in Texas 3 years ago and it died within 3 months. The horseshoe valve is still available at parts places. Part number F420 at Autozone."To Find yourself, you must first lose yourself"
-1973 Volkswagen Bus Westy
-1986 Honda Magna 700cc
-2011 Subaru Outback
Originally posted by porschpow View PostAre you serious?!?!?!?!?
Yes. The Parking Brake Release motor (I call it an actuator) is no longer available. The control valve is.
Like the OP, I also hear hissing in the dash, which I was told is the crescent valva which is on top of the steering column"To Find yourself, you must first lose yourself"
pull the white line out of it and plug that nipple. If the hissing stops, it's not the valve, but the parking brake release. no fixing that, just plug the feed line. Otherwise, replace that valve and have a nice day.
one of the lines to the horseshoe shaped valve should be white... either the line itself, or the ends. That one goes to the vacuum actuator. This process is to test the system to see where the exact leak is.
