What's the best oil to use in a 20 year old Marquis?
    Hi, Just bought 1994 Grand Marquis. Rides nice, motor purrs. It has 138,000 miles on it. Wondering what would be the ideal motor oil for it. Some oil change places advertise, "Hi mileage oil", I checked with them and it's a 10w-30w oil. Would that be OK. I thought maybe a heavier oil should be used, at least 10w-40w. What are your suggestions? Thanks, Ed
    Hi Ed,
    Welcome to the site. I wouldn't think you'd need to go with 10w-40 oil. The early 4.6's that our NC Highway Patrol used popped oil filters when using 15w-40. I believe these early engines used 5w-30. My 03 Mustang Mach 1 is a 4.6 DOHC and Ford spec's 5w-20 for it. Think the previous owner used Mobil One in it so that's all I've ever used in it. Welcome to the site!! Guess you have what all these guys call an "Aero". All of my Panthers are 5.8L (351W) "boxes". Stan
      5w-20 do not use 10w-40 in a 4.6.
      Past Panthers
        Thanks guys for the info. Even tho it's a 20 year old car, it's still new compared to my other car, a 47 Plymouth. I use Rotlla T 15w-40 oil, which has zinc. I guess the more modern, later cars, didn't need zinc as much as the older ones. But, I'm curious, what would happen if I put the Rotell T in the 94 Marquis? Ed
          See my first response.............15W-40 is was tried in the early 4.6 equipped Fords and they blew the oil filter cans off. From this experience, I'd say you'd have a "lot of oil pressure" !!
            if you hear constant tapping with 5w20, switch to 5w30. (this probably won't be an issue)
              I can believe this. I have seen the gauge in my '92 approach 100 psi when cold (I got on it kinda hard though). That's with 5W-30.
                I use Max Life. Walmart's version of it works good too. It's for cars with more than 75,000 miles.
