About to carb an 85 Grand Msrquis wagon. Need some help in figuring what needs to be and can be removed as far as vacuum lines, sending units wiring etc.
This is a 302 with CFI and AOD tranny.
I have a Edelbrock 1406 and Weiand dual plane..... HEI distributor and set of Lincoln logs. Had planned to use a set of 1970 heads but that's not happening at the moment so using the stock 85 heads. Motor had just under 100K on it. When it runs it runs good but the mileage is 5 to 7 MPH. I've changed everything except the ECM. and no... can't find a vacuum leak. I'm sure it needs a timing chain and have that to change too.
Want to use the AOD and the cruise ( I understand it's a stand alone unit.) The AC and whatever other power items I have ... a bunch
Need to know about the Air pump... can it be completely removed. I'll be removing the Cats ( I can do that here in NY state.
Anyone have info on setting up the TV on the tranny... I've heard many have used the stock setup or should I go with the Lokar setup
HELP HELP HELP. What to do this in the next couple days. Point me in the right direction.
Amen,
Rev
Amen,
Rev
