CFI to Carb 85 Grand Marquis HELP HELP
Got a Protronix unit for the autolite dizzy. Running the fuel lines is become a PITA. I had all new nylon lines installed I've got the pressure line all set to the regulator but had to cut the return line because the coupler broke when removing the metal line.I picked up a repair kit.... (expensive for what you get) I have the union mated to the repair line. I was able to do that in the garage with a heat gun on medium setting. now I have to heat the return line going to the tank with the heat gun,,,, don't like the idea but it is what it is,
And no, no, no the hot water trick Dorman suggest is bullsh*t. I'll let you know if I make it or not lol.
had her running (for a bit) today. had to dump some gas down the carb. Having a problem getting the Fuel pump working. Had to cut the wires going to the ECM. I have the Orange with black stripe going back to the cockpit and have the pink with black going to the bottom of the starter solenoid. I have a Red wire and brown with green (I think) that need to be hooked up I believe the brown is the ground and the red goes to ignition but not sure. I think the pink with black needs to be hot all the time but that doesn't seem to be the case.
The plug that has the Orange wire going to it has two wire that I had to clip. One is Green with purple stripes and the other is red.
I want to run this with as much stock as I can but thinking I may have to just redo the electrics to the pump all together.
Motor is pretty well set,. Carb and kick down are fine. Having trouble getting the fuel pressure down to 6 1/2 to 7. Not sure if it's the regulator or the gauge.
Still have to get the tail pipes installed. Have a set of stock (new) sedan tail pipes, I think the muffler man can cut and bend to fit behind the rear tires. That and remove the cats.
Still have to set the gauges up, just running the water temp, oil pressure and volt meter for the time being.
Needs a front end alignment I think..... feels a lot different with the 16's on there.
The car does shit and get now.... hope the mileage got up from 5 mph lol.
Can anyone suggest a short center console I could use. I like the 40 60 style front seats and they are in great shape.
Would like a place to put gauges and cup holders.
Any updates on this? Did you use the stock fuel lines and all?__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
