4V is four venturi, or four barrel. Ford did not make four valve heads for this motor.
1970 351W 4V Factory cast heads
ThankYou03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
check the dyno comparison on the 2v vs 4v heads on powerblock.
http://www.powerblocktv.com/episode/...2#.VMb-W_7F_ao
Originally posted by sly View Postcheck the dyno comparison on the 2v vs 4v heads on powerblock.
There are actual 4 valve heads for a 302 / 351W they are hard to find and are only good to around 6000 rpm do to design limitations on the valve train. FMS had them in thier catalog for a couple years. There are also 3 valve heads by Gurny Westlake which were about the best SBF head better than the 4V 351C heads but very rare almost purchased a set for my Shelby GT350 if I hadnt been drafted.Scars are tatoos of the fearless
Sure are neat lookin'
that's fun. I've heard of these, but first time I'd ever seen pics.
Looks like a mechanical clusterfuck.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostLooks like a mechanical clusterfuck.
Used to work with the engineer behind thier design. Guy was over 80 years old. Also responceable for copying the GT40 heads from the DOOE heads intake runners and older 260 heads exhaust ports. He was also working on a tunnel port Pinto 2.3 head while I was working on a split port version. The split port kick butt. Niether were produced as the engine was slated to be discontinued. My split port was in testing stages when it became more important to work on the Auston Martin engine per Advance engine designs new department manager. Bit of a wrong move in my book but thats politics.Scars are tatoos of the fearless
