Where's my oil going?
    I bought a 1991 MGM GS and had a bunch of work done on it: new belts, plugs/wires, valve cover seals, PCV, etc. It runs beautifully, idles smoothly, and has... well, not plenty of power, but as much as you'd expect from a stock 5.0 .
    When I bought the car it had brand new oil in it. I drove it for a couple of thousand kms and noticed the oil was getting dark, so I figured I should change it. Only 0.5 L (yes, half a litre!) of oil came out when I drained it! This, despite the oil showing ABOVE FULL on the dipstick! Yikes... so, I filled it up and drove it for another few hundred kms, keeping an eye on level and colour like a hawk. I noticed it getting dirty again (but level still high) and so I changed it again: 2.5 L came out this time. I filled it again, this time with some SeaFoam added to the crank case in case sludge is collecting the oil somewhere. After only a few hundred kms of driving, only 3.75 L came out.
    So, basically, I'm using about a litre of oil every few hundred kilometers. There are no drips, no smoke, no smell, no nothing to suggest that oil is being used. The dipstick shows beyond full all the time, and it does change colour as the oil ages, so it's not like it's "stuck" on old oil somehow. When I shut off the car, there's no significant sound of oil dripping back into the pan like I would expect.
    After an oil change, the "oil" idiot light stays on for slightly longer than normal, which I would expect as the oil pumps through the filter. Then the light turns off. So it seems like the pressure circuit is working fine and, even with only 0.5 L in the crankcase, the car still had oil pressure, which blows me away.
    Anyone have any idea where my oil is going?!
    1991 MGM GS - stock summer cruiser, with lovely A/C
    1977 Cougar XR7 - stock summer cruiser, with no A/C
    2009 G8 GT - un-stock summer cruiser
    A couple of Elantra Tourings - I have a strange obsession with them!
    Disconnect the breather tube between the oil fill and throttle body, then, with the car running, see if there is noticable exhaust looking fumes coming from there. I had one do that and I figured it was bad rings. Unfortunately I never actually confirmed this theory. This one was breathing out 5 quarts of oil over just a couple hundred miles and it looked like exhaust fumes coming from that breather.
    Vic
      Just to be sure, you do know there is 2 drain plugs on the oil pan? One in the front and one under the belly. If you just undo the front one, you will only get about a quart or so out of it.
      WagonMan
      89 Colony Park
      90 Colony Park
      70 HEMI Daytona Convertible
        WagonMan
        This. came ready to write the same thing. A lot of people see the front one and just touch that not even knowing about the rear one. Good luck.
          Wow, no, I didn't know there were two plugs. When did they introduce that? My '77 Cougar with the 302 only has one plug (off to the side, so obviously a different pan); why on Earth do they need two plugs?
          Now, forgetting about it (or not knowing about it) wouldn't explain why I'm getting different volumes of oil out with every change, would it?
          I'll check into that breather tube, too.
            1979 on the 5.0 in the Fox and Panther chassis. The crossmember is in the way of a large front sump but Ford oil pumps are in the front. Rear sump is where the oil mostly lives, front is where the pump sits.
            better question is how much oil are you putting in each time? If you're adding 5 quarts but only draining the front it will be way over-full. I wouldn't put much worry into the oil breather until the oil is at the proper level either. Its going to have issues if the level is way over full.
              Thanks. Yes, I’ve been “filling” it every time, which now I realize is why I’m getting more out of the front drain plug every time. Good grief, it would have been nice if the Chilton manual had mentioned two plugs! Anyway, I guess I’ll be draining the oil this afternoon LOL!
                Funny? story. I knew a garage that would only drain the rear of the pan and wipe the outside of the oil filter to make it look like he installed a new one. This shop ripped everybody off. WagonMan
                89 Colony Park
                90 Colony Park
                  I can’t believe it ran with that much oil in it. It would be interesting to know how much comes out. I bet it’s at least 8L.
                    Just changed it and got about 7.5 L out of both holes (insert mom joke ), not including the filter. I'm sure glad I came to you guys!
                    It ran really well, actually, with that much oil in it. Hopefully it didn't get used to it and start running badly with just the required amount!
                    At least the dipstick is now showing full and it's all clean.
                      I have a little sign that I put on the dash when I need to have an oil change done by a shop. " This car has 2 oil drain plugs, please drain all motor oil."
                      I always check the dipstick after an oil change, If it reads above full, I know they did not drain the front sump. Of course they will lie and say they did.
                        The trick is to get a good enough oil leak going that you never have to change the oil, but keep topping it off one quart at a time.
                          Not a good trick. The sludge and contamination in the oil builds up until you end up making nasty carbon cookies in the engine.
                            Well, yes, you might wreck the engine. But all that oil will coat the underside of the car, saving it from rust. And while 302s are a dime a dozen, the number of rust-free Panthers dwindles by the day.
                              Umm, you must be joking. Just use some used motor oil if you're that cheap rather than ruin a good engine. Better yet, use a product designed to fight against rust like Fluid Film or Krown. I'm really liking Fluid Film over Krown these days but Krown is all I can get applied to my car and I don't feel like buying an air compressor and all that or making a total mess in my driveway/garage with that schmutz. I get 'em done at a facility and then touch up what they miss with some cans of the product, all without sacrificing an engine or anything else for that matter.
