Cooling problems
    Cooling problems
    I've replaced the entire cooling system on my 85 but the car's still getting hot, got a single core rad out of a 91, aluminum duralast water pump that came with the car, thermostat, all new hoses, fresh coolant, and I flushed as much rust out as I could, what am I missing?
    The fan clutch is working fine, but it's getting hot enough that the red "engine" light is coming on. Past 2 times it's gotten hot enough that the hoses are stiff, but hasn't blown any coolant out
    Is the engine warning light temperature or pressure activated?
      Get a proper temperature gauge on the vehicle. It'll tell much more of a story than the warning light if its operation is suspect. The switch engages based on temperature, and I think it's north of 240 degrees. Usually the hoses will be pretty firm at operating temperature with pressure built up.
        https://photos.app.goo.gl/7ZiEdapwtwHQmizt9
          how have you tested the fan clutch?
          hose tells me either its got a lot of air in it, or its not building pressure. No pressure is either a leak or a bad cap, or its not even warmed up. The idiot light is not to be relied on, you need at least an IR thermometer to shoot the thermostat housing, or better a real gauge.
            Well the one that was on it before would freespin after you shut the engine off and you couldn't feel it blowing, the one that's on here now you can feel it blowing good at idle
              Sure no large pockets of air in the system?
                I'm sure I got the air worked out. When I did the flush I pet it run for a good couple hours, and I've been driving it 15 miles to work and back for 2 weeks and haven't had to add coolant except for the one time it started boiling out cuz there was a leak
                  I took the video after driving 15 miles to town and back on a 65mph highway with hills, and I FINALLY have all the leaks squared away
                  So the hoses need to basically be hard enough you can't really squeeze them then?
                    Yes. That's when you know it's under pressure and at full operating temperature. Should be about 12-15 PSI.
                      At the moment I have 2 16lb caps I've tried
                        I have seen aftermarket radiators where the neck is made wrong and the lower cap seal doesn't actually seal on anything. Causes it to build no pressure, it just dumps coolant into the overflow bottle. Can usually tell this by squeezing the hose when its cold. if the level in the overflow bottle goes up as you squish the hose, its not sealing.
                        related to the overflow bottle, if that hose isn't in good shape or its leaking at the connection on the radiator it will burp coolant out but suck air back in, producing an air pocket.
                          This is a stock radiator that I pulled out of a 91, I'm gonna see if I can find the original cap that went to the radiator and see if that does anything
                            How about getting an OEM cap made for a 91? That way, you know the cap "shouldn't" be a potential problem. By the way, do you know the radiator is clean in and out?
                              Just echoing the suggestions that you employ a thermometer.
